Need help with misfire
I was having some issues with pinging at WOT so I added some Octane booster, 20 miles later I start to get a miss, 2 miles later when I get it home it is starting to miss pretty good. Pulled the plugs and they all look okay?? Truck only misses when it has a load, seems to run smooth at idle. Hooked up the Predator and all I see is a random misfire code. Truck is an 05 with 71000 miles and a Magnacharger. Anyobdy got any ideas??
I get problems like that due to our lower octane in Alaska. I have to change the plugs out here and again.
If you are getting pinging at WOT, you are probably running too lean and need a retune.
I think I'd try a new set of plugs and hope that is a quick and easy fix on the missing, then get either the tune worked on or find a source of higher octane fuel.
Well, the saga continues. Dealership called on Friday and told me that the COP was bad on cylinder 7. They replaced that and the plug and hit me for 300 bucks. Pickup the truck tonight and the first thing I notice is no miles put on it since I dropped it off, great, sure enough I get out on the road and put a load on it and it starts missing right away. I can't believe they wouldn't test drive if after replacing the coil.
A set of tunes would allow you to change based on the situation......
Examples
Bad gas
Cold weather
race
etc............
Last edited by anaheim_drew; Dec 30, 2007 at 10:05 PM. Reason: Wife needed help in den........I went.........end of story
