Supercharger specs.
Old Jul 19, 2007 | 08:38 PM
anaheim_drew's Avatar
Originally Posted by MeanGene
I went to the Roush web site and could not find any information on the warranty.
I am undecided at this point if I even want to add an SC. If I do, I am not going to be pushing it hard and will keep the 8 psi boost level. Hopefully I won't need to take advantage of a warranty. I noticed that it looks like Whipple makes that charger for Roush or do they just look alike? A couple of things I don't like about the Roush is the long snout, double the belts and pulleys, what seems to be a smaller intercooler, and an air intake system that is not really a cold air intake. I am sure there are good reasons for the differences, but really can't grasp them just looking at a couple of pictures over the internet. There are things that I don't like about the Whipple, no freely available manual, uses stock injectors, difficult to run an under-drive pulley, stock narrow belt may slip under load.
Those are some of the pluses and minuses that I can think of, please add - correct
No Whipple does not make the Roush charger
It is a cold air intake on the Roush
Old Jul 20, 2007 | 02:00 AM
MeanGene's Avatar
I don't think any of the so called CA intakes that are basically a three sided metal shroud that must seal to the hood are effective in preventing under hood heated air from entering the engine. One fully sealed Cold Air Intake maker challenged this type of Air Intake to take their dyno measurements with the hood closed instead of open like they usually do reducing the claimed HP increases by a significant amount. I don't have any personal experience but it seems to make since if you pay for a CAI, it should actually draw in cold air? The one on the Roush and similar setups will not! I am not confident that a non sealed intake system will hold up under adverse condtions, rain, dust, etc..
Old Jul 20, 2007 | 03:01 AM
Why ask a question if you are not open to the correct answer?
The Roush with the open intake is the old non intercooled one
Old Jul 20, 2007 | 03:49 PM
MeanGene's Avatar
What makes you think I wouldn't be open to a correct answer?
All I have to go on is what I see on the Roush web site and there is no sealed CAI that I can find for a 2004+ F150. But hey, that doesn’t mean there isn't one, and that doesn’t mean that I don't believe you, it just simple means I haven't found it.
Old Jul 20, 2007 | 05:56 PM
Here is the Roush system and it is available Im in Anaheim if you want to see it
.................................................. ....................Ship date 11, April 2007
Old Jul 20, 2007 | 08:19 PM
MeanGene's Avatar
Nice, looks good. I thought you used a Powerworks?
Old Jul 20, 2007 | 08:42 PM
I do run Powerworks and I am very pleased with it.
Old Jul 20, 2007 | 11:04 PM
khendrix2374's Avatar
The Trilogy kit screws into the driver's side fender well and pulls ONLY air from there. It doesn't seal to the hood.
Just some thought.
Old Jul 20, 2007 | 11:15 PM
MeanGene's Avatar
Just some thought.
As does the Whipple, Roush (as I have been edified) and probably a few more.
