Drive'ability issue with Whipple and 60#hr injectors
Old Jun 27, 2007 | 01:58 PM
adami67's Avatar
Hi all, It's been a long time,,,
I'm currently having major drive'ability issues with my Whipple and 60lb-hr injectors (and possibly other stuff).
I'm looking for folks that have similar set-ups and are using SCT programs.
Although my catch code will be different, I'm more interested in comparing values.
If you have a non-lighting equipped with a Whipple and 60#-hr injectors (and a BA-2400 MAF would be good) and are using SCT software, could you please PM me and possible pass along your program so I can see what's wrong in my program.
-a
PS: I did make 453HP and 534 ft-lb torque at 16psi on 91 octane gas on the dyno, but it drives like crap everywhere else..:-(
Old Jun 27, 2007 | 08:24 PM
SCOTTE`screw's Avatar
could be a tuning problem...60 pound injectors? i would have thought 48`s would be good? did you have it dyno tuned?????
Old Jun 28, 2007 | 10:54 AM
adami67's Avatar
Yes, it's been tuned on the dyno.
See signature; it made grade power on the dyno, but drive'ability sucks.
I'll take a program..:-)
Old Jul 4, 2007 | 05:35 PM
rafa26's Avatar
Adami67, you need a real tune for sure. Your HP and TQ numbers are very low for 16PSI.
You shoud be over 500RWHP/600RWTQ , a lot of guys here with heavy 4X4 F-150s are making over 400RWHP with 10PSI only.
Have your truck tuned by a real good tuner and you will make a lot more power than that.
Old Jul 4, 2007 | 09:03 PM
major drive'ability issues ...please explain further...
but i`ll tell you now...if anyone can figure out your truck...it would be mike troyer...
Old Jul 5, 2007 | 03:27 PM
adami67's Avatar
Well, one of my drive'ability issues was due to a spark plug with a gap of about 0.070" when it should have been 0.032"
The side terminal was sort of sticking up at an 18-20 degree angle. It would fire and stay lit as long as I wasn't on the throttle too hard.
I changed all the plugs and the "fluttering" (it was miss-firing) is gone.
I'm sure that was affecting my power as well. I think I made 450 HP, 540 torque on only 7 cylinders!!
I'm planning to drop the boost from 16psi to 14psi and add more timing.
I've noticed that additional timing drastically improves throttle response in all RPM ranges.
I don't want to have to run octane boost, so I won't be going too aggressive on the timing.
-adam
Old Jul 5, 2007 | 06:03 PM
wow that is a big gap..i think 50 is standard on reg f-150`s....but i think the lightning guys run gap at 34....you may want to post something there..
glad ya figured it out,sorry i was no help
