Supercharger and 4WD
I have had my Roush intercooled Supercharger set up for over 6 months now and I am just curious. Has anyone else with 4WD added a supercharger or turbo to thier truck? Obviously I dont drive it in 4WD on dry roads but I am assuming the added weight from the 4WD hardware is giving me quite a performance hit.
What is it that you want to know about supercharged 4x4s? How much power loss through the drive train? Can you drag race in 4wd? What's your ?. I'll tell you this, my dyno shop tells me that I lose about 25% in power due to the auto trans, and 4wd components. Of course that's all just an estimate on their part. My 01 SCAB 4x4 with a Procharger puts down 320/403 to the wheels. We estimate that's around 400 crank hp. not sure about the torque.
You have about 6-700 lbs of extra weight. In 4x2 you loose a little more because of the T-case. If you launch in 4x4 expect to see the front wheels pull a little to the side like a front wheel drive car. I haven't launched in 4x4 on dry dry roads for fear of breaking the t-case and or the tranny. My friend with a powerstroke is in the 13s and launches in 4x4. He spins the tires on the rims when he does.
JMC
JMC
JMC
JMC
Anyone?
On lose surfaces, the wheels can slip enough to eliminate binding.
On high-grip asphalt or concrete, the wheels don't easily slip.
Same reason why a full-spool rear diff is bad on pavement.
Originally Posted by Jordan not Mike
There is no center diff, so when you turn on dry pavement you get binding in the driveline (becuase the front and rear wheels turn at different rates). This is very hard on the components.
What about the AWD trucks? The clutch in the t-case for the front drive engages as wheel slip is detected. Will this "soften" the power out to the front at all? Or is it gonna be just as bad as 4wd if you nail it?
--Dan
--Dan
Thanks for the reply guess I wont take any chances doing a 4wd supercharged launh on dry pavement....
I don't know about a manual tranny or clutch, but Lightnings aren't having a problem breaking the 9.75-inch rear, so I don't think you need to worry about that.
Even the 8.8 is pretty stout, and can be made bulletproof, but I guess it all depends on your power level and traction.
