Eaton M90 ?
Old Apr 22, 2007 | 11:15 PM
indynotch50's Avatar
Eaton M90 ?
A guy I know is selling a eaton M90 charger for cheap. I was thinking about putting it on my 2000 5.4, however I cannot find any information on this charger or what it would take...
Any suggestions?
Old Apr 23, 2007 | 12:35 AM
phil6608's Avatar
Any suggestions?
Is it a complete kit for your truck?
If not it's not worth messing with.You will need way to many parts to make it work.
You would be better off doing this! Check it out.
http://www.madenterprise.com/scparts.htm
Phil
Old Apr 23, 2007 | 04:17 PM
I found out it's from a supercoupe. They put them on 3.8 liter engines. From looking at it, it will take quite a bit of work and that it won't just bolt up.
Old Apr 23, 2007 | 04:20 PM
Do you have to have all that stuff to complete the charger?
Basically this is just my old truck. I have a mustang for a race car and was wondering if I could slap a charger off a lightning on it and just go from there without much hassle and cheaply.
For $2800 I can get a new killer set of heads...
Old Apr 23, 2007 | 04:27 PM
phil6608's Avatar
If your doing the install you can do the Lightning swap for about $3000 to $3500
You have to have all the parts + a custom tune.
Phil
Old Apr 23, 2007 | 06:21 PM
Jordan not Mike's Avatar
M90 on a 5.4 isn't a good fit IMHO, too small.
Look at the dyno sticky...decent torque but HP isn't great.
For the same amount of work (maybe less) put a Lightning blower on it...or a different blower.
Old Apr 23, 2007 | 07:55 PM
lowflyingbird's Avatar
Lightning kit for less
Hi,
You can do this for less than what I saw in that link. Keep in mind if you are willing to keep it too 5-6 psi. The intercooler is not a must. You will need the Lightning SC unit, lower manifold mid plate (intercooler housing)NOTE: SC lower manifold and mid plate must match in years,99-00,01-04, upper plenum,TB, tensioner bracket ,harmonic balancer, lower SC pulley "caged", a Harley upper pulley,a single 255lph fuel pump, a FMU#8 or #10 disk.
I'm doing it myself, and I have done poss. displacement blowers on nat. asspired vehicles of mine before. Granted going the FMU route is the Low-tech caveman way of going, but it works.
If your interested in proceeding, I strongly recomend the "NLOC" website.you can get great deals on many peoples take off parts.
If you want I can start you on the way with two parts,
a Upper Lightning plenum, and a crankshaft SC pulley with cage.
send me an email if so.
ksilibovsky@hotmail.com
Lowflyingbird
