Smaller pulley?
Originally Posted by Dbl G
There are several guy's that are wanting a run of Cogged S/C Pulleys made up however they/you all need too get together as a collective.
I produce groups of, verses one or two.
If you are interested I can hook you guy's all up and see where it goes.
If your are interested in just a normal pulley I may / might be able too slide it in with there group.
I would need an upper too measure for shaft size and location on the S/C shaft, backset's and what not.
Garrett
Garrett
Is it a Whipple and the correct shaft size needed and do you know the outer diameter you want.
I would only need it for a day and then ship it back.
As far as getting some peep's together that is and will be the fun part...
Yes, it's a whipple. I would actually want two pulleys, a 2.75" and a 2.5". 2.5" for later when I build the engine to handle 450+hp.
