What else Do I Need with this Lightning swap
Old Aug 18, 2006 | 11:34 AM
jjszabo's Avatar
I can get a new 2003 FORD 5.4 lightning supercharger assembly that comes with 8 coil packs, fuel rail, injectors, wiring, intake, supercharger, new intake gaskets, and throttle body. What else would I need? Fuel pump, brackets is what comes to mind - any thing else?
All help is appreciated from the supercharger guru's - Mad Mike, any comments?
Thanks,
Jeff
Old Aug 18, 2006 | 02:14 PM
brahmus's Avatar
madenterprise.com
the list can be found there.. Did you get then upper/lower intake manifolds and intercooler?
Old Aug 18, 2006 | 03:06 PM
jjszabo's Avatar
upper and lower intake yes - intercooler, no. I have not bought it yet - he wants 1600 dollars for this assembly. How does this sound?
Thank for the reply.
Jeff
Old Aug 18, 2006 | 03:55 PM
raider's Avatar
Jeff
1600.00 is the norm for the kit...all the parts u need to finish the install can be found here
http://madenterprise.com/scparts.htm
any ?'s or help Mike can help you out
Old Aug 18, 2006 | 04:11 PM
brahmus's Avatar
1600 and you don't get the intercooler!! or do you mean Heat Exchanger? Look on ebay, there are kits that go for 1400 then you can pick up the rest from Mike.
Old Aug 18, 2006 | 07:27 PM
jjszabo's Avatar
1600 from ebay without intercooler.
What is the heat exchanger? - Sorry if this is a dumb question, but I am just starting to understand the installation of superchargers.
Jeff
Old Aug 18, 2006 | 11:02 PM
brahmus's Avatar
The heat exchanger goes behind the front bumper and uses cool air to cool the coolant that flows throught the intercooler (under the blower in the intake manifold) that cools the charge air.
