What gauges your runnin?
Old Jan 18, 2006 | 08:48 PM
CDB03STX's Avatar
Just wondering what gauges you s-chargers are using. Boost, A/F, Fuel Pressure, etc.
I got to fill a hole and trying to decide which gauge to fill it with.
CDB03STX
Old Jan 18, 2006 | 09:15 PM
Neal's Avatar
HI!... I'm running the following AUTOMETER gauges :
- PHANTOM series
- 2-1/16 BOOST/VACUUM
- 2-1/16 TRANS TEMP
- 2-1/16 COOLANT TEMP
- 2-5/8 FUEL PRESSURE
- 2-5/8 OIL PRESSURE
- 2-1/16 INNOVATE MOTORSPORTS digital wideband A/F gauge
Just ordered :
- 2-1/16 NITROUS GAUGE
- 2-1/16 VOLT METER
- 2-1/16 EGT
Old Jan 18, 2006 | 09:52 PM
justjames80's Avatar
I have AutoMeter Ultra-lite gauges.
Mechanical boost, electrical fuel pressure, and electric trans. temp. I use a LM-1 to datalog A/F ratio when needed. Plan on using the LM-1 to calibrate a A/F ratio meter for custom defined outputs.
Old Jan 18, 2006 | 10:12 PM
zombiemachine's Avatar
my goodness Neal, you're running out of places to put yer gauges! dood the gauges mounted to the hood is effing hilarious!! i dig what you did for the A/F gauge though. did you fab that panel yourself? pretty sweet...
Old Jan 18, 2006 | 10:42 PM
Neal's Avatar
HI!... I'm a old school muscle car guys so fuel/oil pressure gauges always go on the hood or cowl. Yes I made up the aluminum panel to block off the heater vent for the A/F gauge. It still has to be painted to match the dash. This SAT I'm picking up another dash top and will be doing a custom 3 way gauge pod like in the pic below.
Old Jan 18, 2006 | 10:58 PM
98Navi's Avatar
I just have a boost gauge right now, but I am going to add a tranny temp and get a wideband and keep it online too.
Old Jan 18, 2006 | 11:03 PM
nice work neal....you're lucky you live in canada man. i laughed b/c if i mounted any gauges to the outside of my truck they would be gone in a heartbeat. ppl in LA will jack anything that isn't "bolted down" imo that is the most logical/visible place to put 'em. kind of gives away the sleeper look though
i've been lookin' for a decent gauge pod online and all i can find is the A-pillar (2 or 3) and the single steering column pod. i really like the dual pod on your dash, that would be perfect for my setup! did you fab that too or was that an aftermarket purchase? i need one of those babies...
Old Jan 19, 2006 | 01:58 AM
Blown2000's Avatar
I'm using Kenne Bell boost and fuel presure gauges in a piller pod
Old Jan 19, 2006 | 08:01 AM
ONELOWF's Avatar
Boost and trans temp on A pillar, XD-1 a/f on column......
I plan to put an IAT on the dash under the shifter.
I like Neal's XD-1 mount, but it would interfere with life support when it hits 115 degrees here in Las Vegas.
Old Jan 19, 2006 | 10:28 AM
adami67's Avatar
Nordskog street digital
A/F (not a wideband, so pretty much useless)
Fuel Pressure
Boost
On the A-pillar
Old Jan 19, 2006 | 10:48 AM
brahmus's Avatar
boost, trans temp, fuel pressure, and a useless A/F light show (narrow band) gauge
Get with this guy.. he has several customs pods he's making for the f-150's
http://fordtruckworld.tenmagazines.com/member.asp?53461 he is on here and FTW I have the dual surfboard pod from him but he has many different setups.
Old Jan 19, 2006 | 06:13 PM
Neal's Avatar
HI!... zombiemachine : The pics of the dual gauges on top of the dash are not mine. Someone in the LIGHTNING section here custom built it for his truck. It's a ONE OFF. I have a buddy that's really good with custom interior pieces so I got another dash top and he's going to graft 3 gauge pods into it. It will look just like the one I posted but have 3 instead of two.
Old Jan 20, 2006 | 02:18 AM
wow....yeah he did a pretty good job on that '1 off', looks totally seamless. i have quite a bit of painting and sculpting experience so i can respect skills like that hey if you are going full on custom why stop at 3, i think you should go for dual triple pods, that would be sweet!
Old Jan 28, 2006 | 01:12 AM
desparado's Avatar
Boost, fuel pressure, temp, and a narrowband A/F gauge. By the way, if you hook it up to the rear 02 sensor, you get an average signal, and not the annoying flip flop you get from the front sensor. It really gives you an idea of where you are. No it is not nearly as good as a wideband, but it is better than nothing.
Old Jan 28, 2006 | 03:12 PM
Mickey_shouse's Avatar
i run autometer boost, egt and trans temp guages. im still debatin on which wideband i want so havnt added that one yet.
