lightning supercharger
Subscribe
Jan 18, 2006 | 03:51 PM
what do you have to do to make the lightning s/c swap smog legal here in california?thanks
Reply 0
Jan 18, 2006 | 10:10 PM
Quote: what do you have to do to make the lightning s/c swap smog legal here in california?thanks
that's an excellent question as i am a california resident as well and in the process of doing an L swap. as far as i know getting a good custom tune is the most important thing to pass smog. a good person to consult would be mike dunn at madenterprise.com. he did an L swap on his truck and happens to be the left coast authority on L swapping'.
Reply 0
Jan 19, 2006 | 08:53 AM
Mike passes smog with his truck and Adam does also...its all OEM parts plus the biggest thing is having your truck tuned correctly
Reply 0
Jan 19, 2006 | 10:52 AM
i have smog here in houston also.. I have upgraded alot but it's all in the tune. You don't want to run to rich.
Reply 0
Jan 19, 2006 | 11:22 AM
Quote: Mike passes smog with his truck and Adam does also...its all OEM parts plus the biggest thing is having your truck tuned correctly
talked to mike this morning and he has not had his had his smogged yet,going to next week.talked to a smog ref yesterday,he said if its off a lightning its an open and shut no go,but because of the harley model theres a good chance of a yes.hes going to get back to me today
Reply 0
Jan 19, 2006 | 11:32 AM
Quote: talked to mike this morning and he has not had his had his smogged yet,going to next week.talked to a smog ref yesterday,he said if its off a lightning its an open and shut no go,but because of the harley model theres a good chance of a yes.hes going to get back to me today
WHAT????? It's the same ****!!!! Tell him he doesn't know what he's talking about and take a look see how many L's are registered in CAli!!! People that don't know should not be allowed to speak!!
Reply 0
Jan 19, 2006 | 05:37 PM
^^^ 100% what he said. There the same blower on the same set up.
Phil
Reply 0
Jan 19, 2006 | 10:25 PM
good thing i'm putting an HD blower and not an L blower assembly on my truck! haha j/k i have to call b.s. on that one b/c to my knowledge the only difference b/w the L and the HD setup is the HD has a bigger blower pulley ie. 6# instead of of 8# on the L (365hp vs. 385hp). other then that i believe the systems are identical. i'm setting up my HD kit for 14# of boost and i have no worries about passing smog as long as Sal or MT provide the custom tune. just get it on a dyno and datalog it if you can and you should be fine
Reply 0
Jan 20, 2006 | 09:04 AM
zombie are you building the short block? I wouldnt run anything more then 12#'s on a stock n/a block
Reply 0
Jan 20, 2006 | 09:21 AM
Quote: zombie are you building the short block? I wouldnt run anything more then 12#'s on a stock n/a block
Ditto!!
Reply 0
Jan 20, 2006 | 01:17 PM
naw i'm runnin' the stock 4.6, it'll be fiiiine yeah i plan on selling my stock 4.6 on ordering a Bullet block from LFP with perf heads and stage 2 cams. i'm not gonna port my HD blower so i'm keeping the boost under 15#. it's gonna rock!!
Reply 0
Subscribe
