ATI 2-core Intercooler Brkt, anybody have fitment problems?
I bought a used P-1sc kit and it came with this intercooler brkt....
Is this the right brkt for my 03?
It's like the brkt or intercooler one isn't the right one for my truck...too far between the frame rails for mounting. I figure it's not the intercooler. The manual depicts the older body style bumper with the air inlet in the middle of the bumber. My 03 is down in the Valance...well below the frame rails. The manual only speaks of the '99-'00 and prior and there are SPECIFIC parts for the '01-'03. I know there is a different brkt for the 3-core. It appears that brkt would be more suitable for the install. Any ideas from ya'll procharger guys? Does anybody have any pics showing their install with this brkt..'00 - '03?
Thanks!!!!
I have a 1998 but I also bought my P1SC kit used and it came off of a newer truck than mine. I have the bracket in my shed that wouldn't fit my year. I'll dig it out in the morning and see if it is the same as the picture you posted. Have you talked to Procharger yet?
Yeah I talked to them and they said I had the right brkt but I'm not so sure he's right. Sometimes the tech people get there info from the manual I already have....
If you have the other bracket, I'll purchase that thang from ya if you will or if not at least give me the dimensions so I can fab one up at work.
Thanks kpaton....
Thanks kpaton....
you cant believe what they say. they told me i had the wrong bracket and overnighted me "the correct one" and guess what, it was the exact same one i allready had. and none of them fit anyways. i had to fab my own out of theirs by drilling holes in the right places and using spacers........
The bracket that I have left over from my install is completely different from the one you posted. The one you have posted is for a 1997 to 1998 install. The one I have is for a 1999 and newer install, I don't know if that would include 2003 because my kit was made prior to that. I can take a picture and email it to you if you want to see if it will work. It has two parallel slots, one vertical slot perpendicular to the parallel ones and a hole above that perpendicular slot.
Part # stamped into it is AIFG31-1
Does it ressemble the one on the right? The Parts list ATI sent me calls for that bracket by the part no. u gave. Good chance its the right brkt.
How much do you want for that brkt??? Here is my email address if you want to send it that way...kbrooks@farmerstel.com
Thanks kpaton...
Thanks kpaton...
The 3 core was not available when my kit was put together, it came off of a 2000 F150, I bought the kit in November 2001. It was installed with the standard 2 core when I purchased it used. They must be able to use that bracket for either intercooler.
