Question for Crash and Procharger Gurus
Old Jun 16, 2005 | 07:57 PM
Jordan not Mike's Avatar
There's a thread here somewhere...too lazy to look for it. (It may be on that "other" F-150 site)...
At any rate, someone put a temp probe into an open-air element aftermarket air intake. No heat shield, filter exposed under the hood.
His results were just as you describe, desperado.
When the truck is stationary, underhood temps rise. But once moving at most any speed, the circulation of air caused underhood temps to drop to just above ambient.
Putting the IAT probe at the throttle body provides the ECU with the most accurate reading, as this air is fed directly into the engine. Not routed through the intercooler and all the piping.
Old Jun 16, 2005 | 10:01 PM
chucks bp's Avatar
I am running a powerdyne with 8# of boost and a vortech aftercooler. Did some datta loging with auto tap on a 90 degree day normal highway driving air charge temp was 97 to 100 degree on a 2nd gear pull from a stop to redline temp climbed to 121 degree and went back to 100 with in less than a minute, my iat is with in 2 inches from the trottle body in the 3 oclock position when I compared results before aftercooler install on a 72 degree ambient without aftercooler doing a pull on the exact piece of road I had temps in the 185 to 195 range and on other occasions well over 200 degree and cruise temps at 72 degree ambient were in the 120 to 130 range. My timing was advanced by 3 to 4 degrees comparing 72 degree ambient and 90 degree ambient. The iat realy pulls timing with the slightest temperature rise.
Old Jun 17, 2005 | 08:37 AM
Jackal's Avatar
Thanks for the info guys, I love seeing actual numbers like this. Very valuable stuff. Thank you too ganiman for the offer. I will let you know when / if I score a kit. (crossing-fingers) BTW, I love that hood and 3 core poking out there.
Old Jun 17, 2005 | 08:08 PM
desparado's Avatar
ganiman,
Great looking truck!
Jackel,
OK, since I started this thread, I gotta show you my hood and 3 core peeking out!
Old Jun 17, 2005 | 08:17 PM
Showoff
Just kiddin' that looks schweet!
Old Jun 17, 2005 | 09:23 PM
ganiman's Avatar
Thanx folks,Theres nothing like a 3core to fill the hole...
Im finnaly happy w/ the front end,I always wanted fog lights(B4 pic https://www.f150online.com/galleries...2620&anum=4774 ).Alls I need to do is fill the 4-5" gap between the lower valance and i/c w/ a sheet metal/plastic housing.Just to make sure the air flo is directed through the i/c core
Frank
Jordan not Mike, Since I finnaly got my Xcal2,this weekend im gonna weld in the bung for the lm1 that I got from you to do some wot tuning.I just need to pickup a 9 pin dim plug to hook it up.Ill post new #'s in a new thread when its done.
Desperado> killer look.an ati must be fun in a 4x..Also ,those cool hose clamps,how much and where?
thnx
Old Jun 17, 2005 | 11:46 PM
desparado's Avatar
ganiman
Re: Cool Hose Clamps
I got mine for a fortune at a custom truck shop in SoCal, but crash showed em off recently. He is selling them. Let me find that link...open new window...search...ummm...can't find it.
CRASH!!! Did I see that on GotPressure? I'm sure you showed those off somewhere. Can you jump in and tell us?
Old Jun 18, 2005 | 12:31 AM
desparado's Avatar
Originally Posted by Jordan not Mike
Showoff
You Betcha!
I posted this so you know what to look for in your rear view mirror going down the 405 (and you can't shake it)
Then all you'll see is this (but the lid will be down)
Old Jun 18, 2005 | 08:50 AM
mikebaby's Avatar
Do you regularly drive down the 405 backwards?
mikebaby
Old Jun 18, 2005 | 10:59 AM
ganiman's Avatar
Yeah Crash,I got that totally backwards..
You see I suffer from self induced dyslexia,which is usually accompanied by a severe case of a.d.d,and dry mouth.It lasts a few hours then just fades away and I return to a fully functional person.
<-----and this is how it starts
Old Jun 18, 2005 | 05:07 PM
desparado's Avatar
mikebaby
No, but that's what people see when
I PASS THEM!!
Old Jun 19, 2005 | 07:35 PM
Jackal's Avatar
desparado, nice setup man...love the Cobra hood, but are those flames on the IC too? SWEET!!!
ganiman,
Crash!, are you saying the IAT relocation requires a custom tune? And it can be done by swapping two pieces of tubing supplied in the kit? Does it require you to lenghten the IAT wires?
