Boost gauge???
Old Jan 2, 2005 | 12:27 PM
Jody007's Avatar
Boost gauge???
I'm trying to figure out what the deal is on my 01 lightning. At first I found out that my intercooler wasn't acting right, (did not bubble all the time), then found a hose from my s/c had been disconnected. (it had sucction to it - a red hose, connected to a metal cylinder on the right hand side of the s/c)
The boost gauge now indicates 0 when I turn the truck off. It used to show VAC. When I turn the truck on the needle used go back down, then rose after I turned it off. I replaced the intercooler pump relay and not much has changed.
So, the intercooler doesn't bubble like I fugure it supposed to...
I dont know. Any suggestions? Anyone had similar difficulties?
Old Jan 2, 2005 | 04:52 PM
brahmus's Avatar
you can get more advise in the lightning section but do not run your truck with out the intercooler working. make certain the pump is running. i had trouble when i didn't have enough coolant in the tank.
