Drop in a falcon engine?
Old Dec 17, 2004 | 10:52 PM
Corpsie's Avatar
Has anyone here considered dropping in the turbo'd 4.0L Inline 6 from the Ford Falcon into an F150?
331 ft-lbs of torque (peak)
322 hp (peak)
Old Dec 20, 2004 | 11:20 AM
Redneck911's Avatar
I don't think that would be a good idea. The F-150, escpecially the '04, is very heavy. And the numbers you posted are peak numbers. Youd have to drive around at redline all the time to get anywhere.
Old Dec 20, 2004 | 12:28 PM
Corpsie's Avatar
Those numbers are higher than the 4.6L V8's output and with a turbo the torque band is usually flatter and over a wide range of engine speeds.
Old Dec 20, 2004 | 09:55 PM
BROTHERDAVE's Avatar
25 Year Member
is the falcon available in the US?
Old Dec 21, 2004 | 03:27 AM
Corpsie's Avatar
Nope, not available in the US. Yet.... *makes mysterious sounds*
Old Dec 24, 2004 | 08:58 PM
Corpsie's Avatar
Originally posted by Crash!
Thinking $$$ and labor, the Procharger will end up making quite a bit more power, and all installed in a day.
Yeah but can you say "this engine is from Australia" like you can with the Falcon engine?
