Powerdyne install. Now what??
Ok need advice.. I have a 5.4 engine,6lbs powerdyne, 19 injectors, 12 to 1 FMU adjustable.
When stomping on the gas at 3000 rpm the engine runs sloppy. I have no custom chip yet, but would let advice to tune this up.
1. Chip/ What type?
2. Spark plugs ok or differrent type?
3. Have 30lbs injectors with matching CL 80 MAF. Should I install? (Have adjustable FMU)
4. Fuel regulator is stock ok or should I install my CL adjustable one.
5. Have a NOS fuel pump/ should install?
6. Anything else??
1. Chip/ What type?
6. Anything else??
Thanks Crash...
I have the 180 thermostat in. I will get the plugs, What brand is AWSF? What ratio FMU do you think I should try?
I have the vacuum hook up at the right spot by the battery. Read your post and got the information. Thanks
Mine ran better after I got bigger injectors, MAF and a custom chip. Go with a tunable chip, not the generic Diablo or Superchip. Good chips are from Apten, Trixters and Fordchip. I'm sure there are others, but that's all I know. Plus, it depends on where you live as to where you can get tuned.
