lock differential
Old May 13, 2014 | 02:18 PM
amfernandez's Avatar
lock differential
Has anyone installed locking gears on their 2013 f150 3.7. I think we have the 8.8 rear end.
Old May 14, 2014 | 02:24 PM
EsJayEs's Avatar
Haven't installed a locker, but an OEM Traction Lok differential is very simple. You can get a new one from Ford Racing, or a used one and rebuild it with the Mustang Cobra clutches.
http://www.fordracingparts.com/parts...tKeyField=6628
http://www.fordracingparts.com/parts...tKeyField=6942
I know they also offer locking differentials. If you stick with the Ford Racing parts, you're most likely not going to need to change anything other than the differential itself. If aftermarket, you will more likely need to adjust the backlash with shims.
And yes, your truck should have the 8.8" 31-spline axle. Soak up all the research you can. I posted about my rebuild recently. May be some helpful information in there for you.
https://www.f150online.com/forums/ot...k-rebuild.html
Old May 14, 2014 | 07:32 PM
Thanks a bunch for the info. Really help me out.
Old May 14, 2014 | 10:13 PM
EsJayEs's Avatar
No problem. You may find more answers in the "Other drivetrain" section.
https://www.f150online.com/forums/other-powertrain-15/
