Help a brotha out
Help a brotha out
Its been so long that I forgot all the information stored in my head when I did the build on my truck.
UCA relocation brackets for my style of truck. Who makes them? Also any aftermarket tie rods? or how they were made to fit?
My degree in suspension geometry never did arrive in the mail.
Michigan Metal Works is the place to go for bagged control arms/relocation kits
http://michiganmetalworks.com/store/...&product_id=70
For some reason I thought there was a bolt on kit to raise the uppers. Id hate to tear back into my powder coating. But if it has to be done ill do it.
I like how they don't offer any tie rods for fords.
97-03 Ford Front End Kit:
Jeebus Joint Upper Arm Pair:
Jeebus Joint upper Arms
Poly Bushings
Fully Welded
CNC Machined start to finish
Flipped Lower Arm Pair
Flipped Chevy Lowers
Lower bushings
Lower bag mount built into arm
Lower shock mount standard
Front End Bracket Kit
Raised Upper Arm Brackets
Upper Bag brackets, built for ford frame!
Upper Shock mounts
Flipped Steering Kit
Custom Machined Sleeve to Flip Tie Rod
Poly Bushings
Fully Welded
Lower bushings
Upper Shock mounts
raised upper mount: you want to keep your existing upper arm?
it can be as simple as cutting your stock one and raising them by 2" with a bended 2" flat bar.
making a bolt-on bracket should be pretty easy for the 97-03 front setup.
check out streetsource forum.
