Belltech it is !!!!!!!!!!! Need Advice !!!
Old Mar 26, 2013 | 02:48 PM
Jrock59's Avatar
After long extensive research i think i am going belltech struts with sp shocks and use a belltech flip kit for the rear . My problem , i have 24inch wheels and only need a 4inch drop in the rear.Do you guys think that using a 2inch lifting shackle to bring it up to a 4inch drop would be a bad idea? Has anyone tried this out? I looked at changing the leafs and going with a 3 inch leaf and 1 inch shackle but i have been told it will ride rough , plus bottoming out issues . Any thoughts ???
Old Mar 26, 2013 | 07:12 PM
BLUE MAGIC's Avatar
I have a 6/8 drop on my truck running 22 Harley wheels on 265/35 tires and the ride is smooth and a lot better then stock.
I do not have any rubbing problems up front and on back my tires rub the fenders a little, since my bed is fiberglass I used some sand paper and I no longer have issues.
btw im running a flip kit and shackles on the rear
and belltech struts up front set at 1 inch drop, 3 inch djm control arms and 2 inch belltech spindles
hope that helped a little but if your going to be running a flip kit I think your fine unless you have beefy tire on the 24s.
Old Mar 27, 2013 | 07:09 AM
EsJayEs's Avatar
If you want 4" of drop in the rear, that is the only way to go. If you change the bump-stop to a shorter one and/or add airbags, you won't have as much worry about bottoming out. If you're resigned to your truck never being used as a truck, don't worry about airbags.
From my experience, I would not use a flip-kit. I did it, and the results were a truck that couldn't haul or tow much. I took it back off and put some lowering shackles and airbags on it. I've been happy since.
Old Mar 28, 2013 | 11:10 AM
maxpat82's Avatar
I'm flipped and helper bag...and I haul(2 motorcycle, contruction debris, etc) and tow as normal(7000lbs toyhauler with more then 1000lbs on the hitch)...and the truck never skat in the rear(airbag)
No way I would go 6/8 whitout full on air bag suspension.
