hey 1slickf150
Old Apr 12, 2010 | 04:54 AM
hlbbig69's Avatar
Originally Posted by 1sickf150
I just rolled the rear front is practically rolled!! The guys that are doing my air bag setup www.1usamotorsports.com did it!! No helper bag the beltech shocks hold up really well but then again I never tow!! Helper bags would definitely be good if your going to tow!! I have a two piece drive shaft so it did vibrate but bot a djm shim kit and is perfect!!! Once again sorry for the delay my computer is back up!!
no problem glad to get on board with you and bankrupt you guys have been there. Done what I want to do so thanks for all your insights on the 3-5 drop
Old Apr 12, 2010 | 07:16 PM
bankrpt's Avatar
http://www.stylintrucks.com/part.aspx?category%7ccategory_root%7c-29=Towing&category%7ccat_-29%7c365=Air+Suspension+for+Towing&canned_results_ trigger=&partfamilyid=2167&partid=601727
this is the air helper kit you need its called slam air made for trucks dropped from 2"-6".
Old Apr 13, 2010 | 12:21 AM
deton8r's Avatar
Originally Posted by bankrpt
Jessie supercrews come with a two piece drive shafts except 4x4s come with 1 piece: )
My '08 Foose SuperCrew came with a 1-piece drive shaft.
Old Apr 13, 2010 | 12:37 AM
bankrpt's Avatar
Ands its also a all wheel drive to huh? 4x4 or all wheel drive super crews are one piece because of the transfer case there is no need for a two piece. When I broke my drive shaft they company that built mine I asked if I could go to a one piece and they said no because of the length, and I talked to Jesse and his is a two piece he just forgot to edit the post LOL.
Old Apr 13, 2010 | 11:40 PM
anaheim_drew's Avatar
Post One piece aluminum driveshaft
2005 4x2 SuperCrew Lariat.
Old Apr 13, 2010 | 11:47 PM
bankrpt's Avatar
Drew what's in your truck LOL
Old Apr 15, 2010 | 04:18 AM
hlbbig69's Avatar
Hlbbig69 there is special helper bags for dropped trucks ill get the part number for the one you will need because the regular ones wont work
BTW thanks for getting me that ifo in adcance
Later
Bankrpt
Old Apr 16, 2010 | 02:23 AM
hlbbig69's Avatar
Hey Bankrpt
Did you ever get that part # for the air bags. The only two I can think of are the ones by mcgauhey, the other I think was super lift. I wanted to go with the firestones had great luck with them for 6 years. My understanding is that the bags from firestone just simply to big to use for my application???????
HLB
Old Apr 16, 2010 | 02:58 AM
bankrpt's Avatar
http://www.stylintrucks.com/part.asp...&partid=601727
The link above
