Bell tech 3-5 drop
Old Feb 28, 2010 | 08:46 AM
hlbbig69's Avatar
Bell tech 3-5 drop
Let me try this one last time" ANYONE"
I an going to put on the bell tech 3-5 kit I have a 2008 screw 2wd wit a 5.4 that has the long bed so it has the two piece drive shaft. Per the instructions to drop it 3" in the front I have to notch the frame 3/8 of an inch where the lower control arm attaches for alignment puposes. For the 5" rear drop the carrier bearing sheet metal box has to be removerd then where this item is removed I need to fab a new mounting spot per bell teck for the carrier bearing. Now the tech line is telling me that they have had issues even with the pinion angle correct set. They have still has issues with this drive line.
Has anyone on this site installed the bell tech 3-5 with the adjustable strut up front on a truck like mine. If so what did you have to do to fix the drive line problem or was it ok with the correct pinion adjustment. A drive line shop told me that there may be about 1 to a 1/2 inch that may need to be cut off the original then rebalanced. Did anyone have to do this when they did there 3-5 drop kit
Thans
Mark
Old Feb 28, 2010 | 09:24 AM
jsvo5695's Avatar
i installed the 3/5 but i have a one piece driveshaft. When you noth the front you are going to have to buy a really hard cutting bit, The lower cross member is really hard metal.
Old Feb 28, 2010 | 10:11 AM
A rotaty file in a die grinder should do the trick.
Old Mar 1, 2010 | 04:21 AM
hlbbig69's Avatar
thanks guys for the info I have the tools needed just concerned about the two piece drive shaft. If anyone hears anything that can add additional info on the driveline please post I only want to do this once, But I am sure it wont end up that way I am always the example.
Mark
Old Mar 1, 2010 | 07:38 PM
jsvo5695's Avatar
Don't quad cabs have 2 piece drive shafts also? There are quite a few of those on here. So if they haven't said anything then you might be ok.
Old Mar 2, 2010 | 04:10 AM
hlbbig69's Avatar
quad as in full four doors or the extra cab. As far as I know it is only related to the four door screw with the 6.5 bed not the 5.5 bed. anyone knows different let me know please I want to get this thing done and done right one time
Thanks Justin for the info
Mark
Old Mar 11, 2010 | 09:10 AM
I helped Stealth install his carrier bearing relocater on his screw 5.5 bed. I believe it was a ground force kit but i could be wrong. we had crappy instructions and the it took several attempts talking out loud before we agreed on how it should go in. He doesnt have any vibrations.
Old Mar 11, 2010 | 10:10 AM
It was a mcgaughy's bracket. I like it better since it has threaded holes instead of clearance holes for the mount.
Old Mar 11, 2010 | 10:57 AM
bankrpt's Avatar
Hey there I have a super crew dropped 4-6" using djm kit if I was you that's the kit I would use also. With that kit you don't have to notch the crossmember at all just cut the tierods for alignment you will not need to cut your drive shaft or anything you will need the carrier bearing relocator though and wont need any shims if I was going to lower another truck I would use djm again now on the other hand I use the street performance shocks from belltech if u need any other help pm me
Old Mar 14, 2010 | 04:28 AM
hlbbig69's Avatar
Thanks eveyone for posting the info, it is very helpful in determining what drop I can do. While still keep the vehicle as a truck for towing.
Mark
Old Mar 26, 2010 | 12:43 AM
hlbbig69's Avatar
one last question for those in the know bellteck 914sp 3-5 drop with shocks includes this is a flip kit with adjustable struts. The cheapest I have found it is $600.00
Anyone know of a place that will sell it cheaper I am gettin the itchy finger summit racing is where I got this price everbody else is about 30 to 50 dillars higher. If you know of a cheaper place please post up any info I will do all the foot work.
Thanks everbody for all the help
Mark .
