Driveline vibration with Eibach 2/4
Old Feb 1, 2010 | 08:20 PM
Carlsson3's Avatar
Taking off from dead stop there is a slight vibration for a few seconds. Subtle, but definitely there. One piece DS on this '07. Rear shocks are cheap temporaries– factory shocks were way long.
Any thoughts? The Eibach kit, as some of you know, does NOT come with shims, and I'm having a hard time contacting their tech service.
Old Feb 1, 2010 | 08:38 PM
You may need some shims. I believe these are Belltech 2.5 degree shims after a quick search for the cheapest.
http://www.amazon.com/F-150-PINION-A.../dp/B000SIAPSG
Old Feb 2, 2010 | 08:32 AM
Carlsson3's Avatar
Thanks. I'm going by the installer's shop today and see about giving him some more work, and $$
Old Feb 2, 2010 | 03:13 PM
see if anyone can check your pinion angle using a digital gauge, and can tell you exactly what shims you need.
Truck looks great BTW!
Old Feb 2, 2010 | 05:49 PM
I love your truck bud. How much did the kit and install cost total?
Old Feb 2, 2010 | 08:41 PM
Carlsson3's Avatar
I'm a dumbass. My truck has a 2 piece DS. I finally got through to Eibach–they said they have been aware of this problem, they modified one F150 with the carrier bearing problem several years ago when they were R&D'ing the 2/4 kit. Eibach, for some reason, chose not to make or include this carrier bearing "drop" kit in their Pro kits. The 2 piece DS needs this to eliminate the driveline vibration. Ground Force includes these pieces in their kit. I'm a little bent that Eibach chose not to deal with this issue in their kits, but I'm stuck with it now.
Thanks for the kindly comments. Total– with 2/4 kit, install, cheap "temporary" shorter rear shocks, and alignment was $1050.
Old Feb 2, 2010 | 08:51 PM
Screw-Me-05's Avatar
Looks good
Ok good to know. This is something I would like to do in a couple of years as I get more and more done. Thanks for the info bud!
Old Feb 2, 2010 | 08:54 PM
That's good to know.
When I bought my Eibach leafs I also bought a McGaughy's carrier bearing relocation bracket for my 2 piece DS. I knew I needed it so I went ahead and got one when I ordered the leafs.
You may still need shims too since the Eibach 4" drop is a leaf/longer shackle drop... With my 4" drop GF leafs I don't need a pinion shim since they use the stock shackle.
Old Feb 3, 2010 | 02:00 AM
TI_F150BLKSCREW's Avatar
Ditto what Stealth said! When I ordered my 2"/3" coils/leafs eibach kit & dampers set - I ordered the GF shackle kit and the McGaughys CB relocator separately to allow for the 4.5/5" drop in the rear to have both on hand just in case the cb relocator on hand. When it comes time to install later this month and I discover that we don't need the CB relocator - it's an easy return; better safe than sorry when it comes to the 2-piece driveshaft - considering the CB relocator added insurance to the install. Picked my CB relocator up for around $54 shipped.
Old Feb 3, 2010 | 08:42 AM
Carlsson3's Avatar
Good info. Thanks.
Is this the part you're referring to- McGaughy's 70014?
http://www.streetbeatcustoms.com/McG...-70014/551171/
Old Feb 3, 2010 | 11:21 AM
Good info. Thanks.
That's it and exactly where I purchased mine - not a lot of stores online that carry them.
Old Feb 3, 2010 | 06:47 PM
Good work, guys.
Old Feb 3, 2010 | 07:50 PM
sounds like yall got it figured out, i would still recommend getting your pinion angle checked even if you dont have any vibrations
Old Feb 6, 2010 | 11:03 AM
sanhozeezee's Avatar
what kind of shop does this? i did a search for drive train, drive shaft etc and there are no shops near my area that come up. is this something a regular garage can do?
