Eibach 2/4 (35112.550) how did you align?
Old Jan 8, 2010 | 08:18 PM
Carlsson3's Avatar
Those with Eibach 2/4, (35112.550), how did you do alignment?
One more question–why does the full Eibach 2/4 kit cost around $520 while the full Ground Force 2/4 kit is around $1100 or $1200? I see the GF comes with shocks for the rear, but that doesn't justify the cost difference, to me anyway.
I wanted to get all this done last summer but I had gotten laid off. Trying to get going again.
Old Jan 8, 2010 | 09:04 PM
I got my GF 9929 (2/4 drop) for less than the eibach kit you've listed, you just have to know where to shop.
As for the alignment, I had no problems having it aligned back to stock specs without any alignment kit.
Old Jan 10, 2010 | 09:20 PM
josh34's Avatar
you will only have the front aligned
Old Jan 13, 2010 | 06:21 AM
OgRedd's Avatar
I went to a professional alignment shop and they suggested adding the adjustable alignment bolts. May not have needed them, but I got them installed with a 4 wheel line up. Truck rides near stock at 2/4 with no issues. If you can, get the Eibach Pro Damper shocks all around. Worth the extra cost. - Og
Old Jan 13, 2010 | 08:36 AM
Carlsson3's Avatar
Thanks all. I don't have to buy a kit from Eibach to do the alignment at least.
I forgot to ask why doesn't either Eibach kit– 2/3 or 2/4 come with shims for pinion angle? Or do they not list it for some reason?
Old Jan 13, 2010 | 09:10 AM
OgRedd's Avatar
I purchased a shim kit separately. I sold it after I found out that I didn't need it with the 1 piece driveshaft. Specialty Products - part #86255 - If you need them, check here: - Og
www.specprod.com
