Negative Camber Help
Old Apr 29, 2009 | 11:41 AM
FX4&EXCURSION's Avatar
Hey guys, I have an 05 FX4 and recently lowered the front end with OEM 4x2 struts loaded with GF 2 inch coils. I was able to realign back to spec however, the negative camber is way to much for my liking. I was looking at the Eibach Camber Kit and was wondering if this will solve the issue. I understand it won't be perfect, but if I can reduce the negative camber by at least half, I'll be happy. It's so bad, I briefly considered reinstalling the 4x4 struts, but decided against since I really like the new stance. Currently the rear is dropped a little over 4 inches, via 2 inch GF Shackles, block removal, and removal of overload leaf. Eventually, I will purchase the Eibach leafs and the Pro Dampers thereafter. Will the 4x2 Pro Damper Struts work OK for my application? I know there isn't many of us 4x4 drop lovers, however, I understand most of the front components are shared with the 4x2, i.e. control arms, etc. I don't have new pictures right now, but plan to update my Gallery in the next week or so. Thanks!
Old Apr 30, 2009 | 04:42 PM
if it says it will fit your truck buy it. Camber bolts generally give you + or - 2* of camber from stock alignment location/angle
Old May 1, 2009 | 10:29 AM
Thanks patman. The pro dampers specify 4x2 however I'm running the OEM 4x2 stuts with no problems other than the crazy negative camber. I somewhat conclude that if the OEM 4x2's work the Pro Dampers should as well. Wish I bought a 4x2 F150 in the first place
