FX2 Project - Eibach 2/4 & 23" Rims - Pictures
Ok I have all the parts i need for my install on Thursday. I'm using the oem stock sensors. Ill Post more pics of the install later. OgRedd & Stealth Thanks for all your help!
Lugnuts 2X14 and Saleen value stems
23" Saleen Rims
305/40/23R Toyo S/T
Eibach Rear Leaf Springs - 3" Drop
Eibach Rear Shackles - +1" Drop ((((I thought there was two holes - 1" and 2" drop holes? What do you have OgRedd? ))))
Eibach Front Coil Springs - 2" Drop
TPMS Bands & Cradels
23" Saleen Rims
305/40/23R Toyo S/T
Those are the right shackles. I sold my 3" Eibach leafs with the Eibach shackles and they were identical to what you have. The GF shackles (and some other brands) are the ones that have 2 sets of holes.
Man, looks like you're all set!
I have those same Eibach shackles you have. The Ground Force shackles have 2 holes. Don't worry, you're good for a 2/4 drop. I strongly recommend the Pro-Dampers when you can get them and a good alignment after install. Stealth, we should be proud. - Og
We need to start a suspension of the month contest.
I'm going to try out my stock shocks first, but i plan on getting a pro-damer kit later. The shop is going to do a wheel alignment for $79.
Good luck, dude! Pics or it didn't happen! - Og
