Air Lift + Lowered with springs and shackles?
Old Mar 5, 2009 | 11:23 AM
Spaceman Spiff's Avatar
i have dropped my truck 2/5 using eibach pro truck kit and 2" shackles, and i bought the Air Lift kit to help with hauling/towing. will the kit fit on my lowered truck? any one using this setup already?
probably should have asked before ordering...:o
Old Mar 5, 2009 | 12:02 PM
I bought a McGaughy's air helper bag kit for my truck, had the same setup as you, and it didn't work.
Old Mar 5, 2009 | 01:12 PM
what was the problem(s)? i believe their kit is designed for a flip kit, which i would think would make the axle closer to the frame than the springs do.
Old Mar 5, 2009 | 01:18 PM
yes but a flip kit goes straight up. Shackles are longer on one side (front to back), so the spring sits at an angle instead of level.
Old Mar 5, 2009 | 02:47 PM
Yes, and closer to the frame. That's where my kit hit when the bags were deflated to minimum operating pressure.
Old Mar 6, 2009 | 02:21 PM
whiplash0452's Avatar
I got the same kit from air lift. It's there slam air helper bag kit I think the part number is 59210. The kit is for a truck with a flip kit installed. I had some problems installing the kit but I fianlly got it in. The upper bracket that bolts to the frame either needs to have spacers put between the bracket and the frame. I welded a plate to give me a flush mounting surface. But make sure you have a really sharp drill bit to get through the frame and go slow with the drill and allow the drill bit to do it's job dont force it or go fast. I will try to get some pics of the installed bags.
Old Mar 7, 2009 | 10:03 PM
cool, thanks!
