rear end
Old Nov 7, 2008 | 09:25 PM
corey v's Avatar
rear end
my rear end sits closer to the right side of my truck its dropped 2/4, and it also vibs down the road dont know whats it is though i know for shure it not my u joints
Old Nov 7, 2008 | 10:01 PM
1fast4.6's Avatar
so your tire is closer to your bedside on the right side? Did you just install the drop? check to see if everything is tight
Old Nov 8, 2008 | 07:16 PM
corey v's Avatar
yeah i put the lowering kit on my self every thing looks lined up but i know its not cause my rear end shakes the it lilke the rear end and tire sits closer to the right
Old Nov 17, 2008 | 11:54 AM
fomoco97's Avatar
check your u brackets to make sure they are in the same holes...if you know what i mean.
Old Nov 20, 2008 | 08:19 AM
Wildebird's Avatar
Check to see if your bed is even on the cab on both sides. Mine is a hare off centered but I guess when they put the bed back on after the Linex coating they didn't get it centered exactly??
Old Nov 20, 2008 | 02:35 PM
Arca_ex's Avatar
My passenger side is lower than the drivers side too. It's because when you have a full tank of gas and a driver inside it will sit level. Mine is about 1/2" difference with an empty tank and no weight in the cab, but with about a 3/4 full tank and me sitting in it it's level.
