Need some help
Old Oct 24, 2008 | 07:39 AM
1badstx's Avatar
Need some help
Can someone with a 5" rear drop tell me what you're pinion angle is? DJM has no idea what to set it to and he ticked me off so i hung up on him
I do have a 2 peice driveshaft and the carrier bearing is installed so it's not that.
Thanks guys
Old Oct 24, 2008 | 01:35 PM
Go to the tech support page on DJM's site and look at the F150 flip installs, maybe it'll give you some visuals.
http://www.djmsuspension.com/product...20support.html
Old Oct 24, 2008 | 10:00 PM
1badstx's Avatar
I've tried that
I'm starting to get fed up with this
Old Oct 24, 2008 | 11:05 PM
So how bad is the vibe? The drive shaft should be just about perpendicular with the pumpkin I believe.
Old Oct 26, 2008 | 12:01 PM
1badstx's Avatar
The problem is with the driveshaft being perpindicular like they say, as soon as you give it gas it twists down from the torque. I need to know how much to offset that.
And it's bad. it does it at low speeds and sometimes when i let off the gas over 50 mph.
We were talking about having my driveshaft shortened at work but i've never heard of someone with a nbs f150 having to do that.
Anyone know of anyone that has a djm kit besides father ford? He's got the 1 peice driveshaft
Old Oct 26, 2008 | 12:46 PM
can you take some pictures of your setup?
sounds like you need about +2 degrees. If you can post some pics i can get you in the ball park.
Old Oct 26, 2008 | 02:18 PM
The DJM kit has adjustability, you can adjust the pinion angle.
Old Oct 26, 2008 | 10:01 PM
1badstx's Avatar
I know. I just need to know what to adjust it to
Patman i will tommorrow when i get off work.
All the cert's i have and i can't figure dang pinion angle properly
Old Oct 26, 2008 | 10:19 PM
On their site it sounds so easy.
Old Oct 28, 2008 | 02:52 PM
1badstx's Avatar
stealth it took me 3 hours to do the whole thing and about an hour to align it. It was easy
Patman these were the best i could get with no lift at the house
Old Oct 28, 2008 | 02:53 PM
1badstx's Avatar
Old Oct 28, 2008 | 05:15 PM
Looks like the 2 piece drive shaft isn't aligned very well which can cause the vibe also.
Here's my driveshaft after the 2/4 drop. (Thanks, Pat. :o)
Old Oct 28, 2008 | 10:59 PM
1badstx's Avatar
I thought about that too. Do you think it would be possible to take the factory plate off and weld two new peices of metal up there? I don't think i have enough room to redrill the holes.
btw a bearing doesn't have to be perfectly straight so it shouldn't be the problem. It could be though
Old Oct 28, 2008 | 11:10 PM
Yah looks like your carrier bearing is a little low compared to the one we did on stealth's truck.
how about a straight (camera level) side shot towards the U bolts?
like:
But it looks like you are nose up so you need to wedge the front end down. Im still gonna guess 1-2* until i can see better pics
Oh my drive shaft is pretty straight too (just for comparison)
Old Oct 28, 2008 | 11:14 PM
It's possible, but if the kit works on the stuff DJM installs it on it should work, correct? I'm stumped.
Man, sorry to say, I would call them :o again, and try to keep your cool , maybe email them your driveline pics and see what they say. Something has to give.
