2 inch drop alignment issue???
Old Jun 6, 2007 | 09:23 PM
capritoms's Avatar
I am looking to drop my 05 SCrew 2/2 or 3/3. I still want a factory rake but just lower than it sits. I use the truck mainly for towing about 4500 lbs...so I don't want the back to look too low with the trailer on it. What is the easiest/best way to do a 2/2 or 3/3 drop or can you even? Also will I have alignment issues after doing this?
Thanks for any help you can give
Jeff
Old Jun 6, 2007 | 10:16 PM
capritoms's Avatar
I just found that eibach makes a 2/2 kit part number 35112.530 ...does anyone have this and want to post pics of it?
Old Jun 7, 2007 | 01:00 PM
capritoms's Avatar
Has anyone done a 2/2?
Old Jun 7, 2007 | 01:07 PM
styxnpicks's Avatar
nope most to a 2/3 or 2/4
Old Jun 7, 2007 | 01:12 PM
capritoms's Avatar
Is yours a 2/3 or 2/4? It looks really good but I am thinking if I go down too far in the back it will look hella-funny when I tow?
Old Jun 7, 2007 | 01:43 PM
styxnpicks's Avatar
I ended up using the belltech 2/3 theres still 3.5 inch gap in the rear with 32 inch tall tires, I have had it weighed down with a bed full of snow, didn't do to bad
heres how the 2/3 beltech looks with 275/45-22's
Old Jun 10, 2007 | 02:58 PM
Screw-Me-05's Avatar
EIBACH 2/2 click on sig. and anything over 2" in the front you will have alignment issues
Old Jun 10, 2007 | 03:19 PM
capritoms's Avatar
Thanks...that is what I needed to know. I will only go a 2/2 then.
Thanks,
Jeff
Old Jun 10, 2007 | 03:20 PM
'06STX's Avatar
What about the rear pinion angle. If you drop the rear about 2" to level it did you need to change the pinion angle.
Old Jun 13, 2007 | 06:46 PM
Some are hit and miss with the new body i got lucky and no shims and no vibe at all but im thinking of going to the 4" in the rear to have it all level and not just a raked look
