Which is + and which is - ?
Sorry I see a post already answered my question.
A simple question- what is the color code of the door speaker wires? I have a 1998 standard cab 150 - in the process of putting in two Alpine speakers. Pulled off the right side panel, removed the oem speaker, then I realized I didn't have a clue as to which wire was postive and which one was negative.
Could anyone give me the color code for these wires? I assume that the left door is the same - haven't pulled that panel yet.
Found on the web using www.google.com to search:
Wire Color (supercab) Color (regular cab)
Left Front (+) Orange/Lt Green same as SC
Left Front (-) Lt Blue/White same as SC
Right Front (+) White/Lt Green same as SC
Right Front (-) Dk Green/Orange same as SC
Left Rear (+) Orange/Red Grey/Lt Blue
Left Rear (-) Brown/Pink Tan/Yellow
Right Rear (+) Orange/Red same as SC
Right Rear (-) Brown/Pink same as SC
Or also, the easiest way to tell is to take a small 1.5volt battery a AA or AAA and run a wire from the pos on the battery to one side of the speaker and the neg to the other, then switch it around. Which ever way the cone moves out, is the pos/neg connection, if it moves inward, just reverse it.
