Box Dimensions
Old Aug 6, 2002 | 03:52 PM
Ascii's Avatar
Box Dimensions
anyone have the dimensions for a box like the subbox.net boxes that slide under the back seat (flip up seats 60/40) for 2 10's and have the little hump in the center?? or similar box plans with dimensions??
Later.
Old Aug 7, 2002 | 01:44 PM
Ascii's Avatar
anyone out there???????
Old Aug 7, 2002 | 04:03 PM
FishGod's Avatar
Question Box Dimensions
If you find out, let me know. I am looking for the same info. I was considering one of their 12" downfire enclosures for the F150 S/C , but the airspace is only .75 cubic feet. The 12" Rockford Fosgate RFD2112 recommend 1.25 with a minimum of .8. Once you count the speaker displacement (362 cu in.) it is not even close. If I want that size speaker, it looks like I am going to have to put one of the lift kits on the back seat & build my own box. I would much rather have one of theirs, because I really don't want to spend all the time building it myself, but oh well.
Old Aug 7, 2002 | 04:29 PM
bmjwright's Avatar
I'm working on an Autocad drawing now (which I'll convert to JPEG). I'm in the process of breaking out all the separate pieces with dimensions. It may be Friday before I can finish it....so if you haven't heard from me by then, shoot me an email @ branwright@comcast.net
Old Aug 7, 2002 | 04:31 PM
Ascii's Avatar
Cool that way i can show the local shop up since they said " That's impossible it will never work" then he tried to tell me that the w3 and w6 had the same mounting depth then i proved him wrong and he was like i dont think they make the JL w6 anymore so whats one more time of proving him wrong? =]
Thanks again
Later........
Old Aug 7, 2002 | 04:36 PM
bmjwright's Avatar
The mounting depth will be at least 5 1/4"....and the box is designed to work with the existing seat level (2002 model).
Old Aug 7, 2002 | 04:51 PM
bmjwright's Avatar
Re: Box Dimensions
I would like to use 12"s, but the box would stick out from under the seat too much for me (my box will probably be about 14" deep). I'd really like a forward fire box, but there's just not enough room without moving the seat up.
Ascii's Avatar
make sure to put in the thickness of the wood and such and i really appreciate this. If you want when your done you can send to my email Ascii .
Later.....
Old Aug 7, 2002 | 05:01 PM
bmjwright's Avatar
Later.....
No problem (I was going to do it anyhow). I'm designing it for 3/4" MDF.
Old Aug 7, 2002 | 05:33 PM
FishGod's Avatar
Re: Re: Box Dimensions
Yeah, I am probably relegated to using 10s as well, which beats the heck out of nothing, which I currently have. But it is interesting that the subbox.net enclosure looks like it uses 12s without sticking out at all. Do you already know how many cubic feet per driver your plans will provide? By the way, that is very cool that you are doing those plans! Please send them my way if you would. austdan@hotmail.com
Old Aug 7, 2002 | 05:34 PM
Ascii's Avatar
I wouldnt need this info but i hear andy is a pain to get a hold of and to ship out the boxes so why get pissed about it when i can either make it myself or show someone what i want you follow what im sayin?? hell if someone else made mdf boxes to form fit and "real" specs about the boxes and was a customer friendly place they would probably put a**hole andy out of business.
just my 2¢
Later.....
Old Aug 7, 2002 | 08:35 PM
bmjwright's Avatar
Re: Re: Re: Box Dimensions
I don't see how anyone can fit 12" under the seat without the box sticking out some....I need to do some additional measuring I haven't figured the cubes yet, but it will be quite a bit smaller than the boxes that require raising the seat.
Old Aug 7, 2002 | 08:50 PM
bmjwright's Avatar
just my 2¢
Later.....
I'd like to mass produce boxes, but I just don't have the time nor resources (heck, I can't find the time to build my own). There's money to be made, but by the time you ship a large, heavy sub box, the cost to the consumer gets too high.
Old Aug 7, 2002 | 09:06 PM
Ruune's Avatar
yeah I saw that 12" box- the volume of the enclosures is .75 cu-ft, which is not very big for a 12" driver -considering that a decent 12" takes at least double that. Trust me- two 10's with a killer amp is enough to shake your fillings loose... besides IMHO 2-12's is too much for a sCab unless you're competing, in which case you'd want to remove the back seat anyhow.
just my $.02 worth
Old Aug 7, 2002 | 09:15 PM
Ascii's Avatar
I think that 2 JL 10w6's under the back seat powered by a JL 500/1 with XR570-CS's in the doors powered by a JL 300/4 would sound great but again thats me. Oh yea for all those that read this that have a where do i put my jack problem i have an idea of where i will put mine out of the way since i am doing the expy console mod i think i can stick the jack in the bottom and build a false bottom on it to cover the jack. I think this will work when im done there will be pics of everything
Later..........
