Rear Door Panels
Old Apr 6, 2002 | 10:42 PM
TRK's Avatar
TRK
Rear Door Panels
Does anyone know the best way to remove the rear door panels in a 2000 Supercab? I found some good instructions for the front doors but not the rear and I'd hate to screw up the panels.
Thanks,
Tim
Old Apr 7, 2002 | 10:42 PM
rtroha's Avatar
Thumbs up No problem
All you have to do is this.
Take out the 2 screws that hold the window latch on. Pull the upper trim panel off that goes around the window. It just snaps in so it should come off pretty easily. Then you'll see 2 screws and a plastic fastener on the top of the lower door panel. Remove the screws and the fastener and the pull up on the panel and it should pop right off. It's really easy to do and should take you about 10 minutes to do. Hope this helps.
Bob
Old Apr 7, 2002 | 11:15 PM
TRK's Avatar
TRK
Thanks!
Old Apr 26, 2002 | 01:20 PM
mthunwardsen's Avatar
Front doors
Hey TRK,
Where did you find the good instructions for removing the front door panels? I am about to do the same. Thanks.
