Sweet Sub Box
Old Feb 22, 2002 | 10:50 AM
blklightn's Avatar
Sweet Sub Box
My amp will mount in the middle section, should look Hot.
Old Feb 22, 2002 | 03:37 PM
crazedf1's Avatar
you build that? looks good.
Old Feb 22, 2002 | 04:39 PM
Robdude30's Avatar
Thumbs up
Excellent job blklightn, lets see some pics after the install.
Old Feb 28, 2002 | 05:37 PM
mr2x75's Avatar
how much cubic feet did you end up with per side
Old Feb 28, 2002 | 11:56 PM
blklightn's Avatar
I ended up with 0.824 ft per side. I just installed it and it sounds unbelievable. I'll post pics.
Old Mar 1, 2002 | 01:00 PM
Blown 00's Avatar
Sweet! How much do you want to make one for my Lightning?
Could you send me the specs and how you wrote Lightning on top?
My e-mail is Basktbalr7@aol.com
Old Mar 1, 2002 | 05:52 PM
andrewjhaley's Avatar
Im interested also. Where are you mounting your amps? and what about the bults that stick up from where the storage thing is, what do you do about those?
Old Mar 1, 2002 | 07:41 PM
blklightn's Avatar
Well I mount the amp on the back wall of the box in between the speakers, I cut the metal studs that the storage thing was attached to with a dremel.
Old Mar 1, 2002 | 07:45 PM
blklightn's Avatar
Oh ya I hand painted that on top with silver latex metallic paint, and than clear coated over it.
Old Mar 1, 2002 | 07:48 PM
blklightn's Avatar
Another Pic, I also have to stick that wire under the carpet. I got a wire to small to run under the door jam thingamajig
Old Mar 1, 2002 | 07:50 PM
blklightn's Avatar
Another Pic
Old Mar 1, 2002 | 09:23 PM
LilBuddy's Avatar
so how much do you think you could make these boxes for? and what is that number in the center? it would be aprreciated if you could clarify the inner space's dimensions. i love that box. does it take up any leg room, or can you put the seats all the way back, and how does it do sitting on the hump in the back? does it fall off, or stay on there pretty good? thanks man.
Old Mar 1, 2002 | 10:13 PM
blklightn's Avatar
As you can see in the pic here I designed it so that when the seat is all the way back it doesn't interfear at all with the center console. The middle section is 14"w by 10 1/4"deep by 12 1/4"high and the top depth is 6 1/4" and the bottom lip thingamajig is 2" high.
Old Mar 2, 2002 | 03:45 PM
LilBuddy's Avatar
do lightnings have the hump behind the seat where the back wall starts? never looked in one to see. i was wonderin cause of the box.
Old Mar 2, 2002 | 04:37 PM
i dont really understand the dimensions, its kinda hard to read, can you type them out please, what is the internal volume of the box also
