Speaker Wire adapters
Old Oct 8, 2001 | 04:44 PM
jmlay's Avatar
Question Speaker Wire adapters
I am in the process of replacing my factory speatkers with a 2 way componit set I had in storage, MB Quart's.
To make a long story short I am not upgrading everything yet and I want to retain the factory connection to the speakers. I have been unable to locate the adapters that plug into the factory harness.
Any one know where I can find these, local to Dallas? I have tried several places and they do not have the correct connectors for the 2001, it is different than the 97/98.
Old Oct 16, 2001 | 10:44 AM
ASVTFordBoy's Avatar
After trying several stereo shops with no luck, I ended up getting some from Crutchfield for about $10 a pair.
Old Oct 16, 2001 | 01:40 PM
abullerm's Avatar
I couldn't find any of the "new" style locally either, so I just spliced the factory harness.
Old Oct 17, 2001 | 09:04 AM
jmlay's Avatar
I'm trying hard not to splice into the factory harness, not looking good. I called Crutchfield and found that Metra Electronics is there supplier for wireing. I hane been to there web site and traded e-mails with there tech's and so far have not found the correct adapter.
Will keep you posted on the progress, or lack there of.
Mike
Old Oct 24, 2001 | 10:02 PM
lightning0513's Avatar
Have you tried Best Buy? You do have Best Buys in Txs. don't you? That is where my buddy found his.
Old Oct 25, 2001 | 12:39 AM
abullerm's Avatar
I tried Best Buy but they didn't have the new type. They had an empty spot on the wall for another Ford adapter but never saw their supplier refill that slot.
Old Nov 15, 2001 | 01:33 PM
LightningCrew's Avatar
I have not ripped open the panels yet, but for those of you that spliced, can you help on the wire colors vs. positive/ negative connections. I plan on installing front door speakers this weekend and need to know soon!!! Thanks ahead for any help.
Old Nov 16, 2001 | 08:41 AM
Wanted to bump this back up - someone suggested using the adaptors, but I want to do this tomorrow, so any help would be much appreciated.
Old Nov 16, 2001 | 03:18 PM
sundog7's Avatar
This place is also a wonderful source for all the little nitty stuff that is hard to find anywhere else. I've had good service, and the one return I had because of improper fit was handled quickly. Check it out:
http://www.partsexpress.com/
Old Dec 7, 2001 | 02:52 AM
LilBuddy's Avatar
i know circuit city has them. employee discount made them about 30 cents a pair. gotta love that. got my amplified thunderform with 2 10"s for $150 shipped directly to me from MTX.
Old Dec 10, 2001 | 11:57 AM
CCarrara's Avatar
LightningCrew,
You don't need to know the color of the wire to find the positieve and negative speaker wires in the doors.
The FAT connector is the POSITIVE side, the THIN connector is the NEGATIVE side. It's that easy. AND, if you plan on doing any work at the head unit, make note if the colors and polarity at each door, cause then you know what the colors are at the head unit too.
PS- Just cut off the retarded Ford speaker connector.
