Installing a line out converter for amp 2019 F150?
Old Apr 14, 2020 | 10:22 AM
Christian Geier's Avatar
Hello new member here, I'm sure this might have been asked before but here goes.
​​So I'm installing a line out converter(LOC) for a JL powered 10" micro sub that I'm putting under the passenger side seat. I have the power and ground wires run. I have a lineout converter that also has remote turn on that will be powered with amp wiring through a fuse off of the amp. My LOC is under the rear seat and I ran about 10' of speaker wires to tap into the main harness next to the driver's side seat. I have found all but 1 wire a (Brown/White) or could be just a White. I'm really kinda confused which ones to use now or if I have the right ones to start with.
I have tapped into the following wires (White/Green) LR+, (Brown/Yellow) LR- for left side, and (Brown/Blue) RR-, but I do not see a (Brown/White or White wire) for RR+???
Has anyone installed a LOC by splicing into the main harness on the driver side next to the driver seat that might have any insight? I'm installing new speakers in the doors this week and I suppose I could look when I'm doing it then, but where's the fun in that?
Chris
