removing door panels
Old Oct 2, 2001 | 03:54 AM
Sean Harris's Avatar
Question removing door panels
I'm looking to install New speakers in the SuperCrew, front and rear. Is there a guide, tips, suggestions on how to remove the door panels?
2001 F150 SuperCrew
Lariat Trim
Highland Green w/Arizona biege
5.4L V8
4x4 Off-Road Package
3.55 LSD
Sikd Plate
Tow Package
17" Cast Aluminum wheels
Leather heated front Seats
Power Driver seat
Moonroof
6 disc changer
Old Oct 5, 2001 | 01:38 PM
Loyd meeks's Avatar
On front doors at the bottom are two screws. Remove the panel where thr door latch goes, it just pops off, the panel for windows and locks pops off under these are phillips and one hex head screw. Lift the door panel up and it will pop off.
On Back doors it is the same excepy the narrow trim piece at the latch side of door pops off and there is a phillips screw there.
Who ever designed these panels did a great job it is the easiest I haver removed
Old Oct 5, 2001 | 01:49 PM
Loyd meeks's Avatar
On the front door at the bottom are two phillips screws remove them, pop the small panel that covers the door latch there is one phillips screw here, pop off the panel that holds door and window switches,there is a hex head here. You can now lift up and the door panel will come loose. twist the light in the door and remove.
On the back doors it is the same except for the trim panel on top door edge,pop it off and remove a phillips screw.
when I replaced my rear speakers they were too deep for the standard holder so i shimmed it out about a 1/4 inch so the magnet would not touch door spring.
Old Oct 5, 2001 | 10:46 PM
Thank for the info. I'm giving it a try this weekend. Any luck with the DynaMat stuff. Does it make a difference?
Old Oct 6, 2001 | 06:33 AM
Took a 1000 watt lamp outside at 4am and 1 hour later I have a brand new set of Infinities in my rear door. I'm off to BestBuy this morning to find a set for the front doors. You saved me about $80 in installation fees.
