best products for system upgrade
Old Jan 28, 2014 | 09:10 AM
FX4Matt's Avatar
hey all,
so as stated in a previous thread of mine im looking to upgrade the factory ford system in my 2012. all I have is sync (no nav or sony).
so my question is what products do you guys recommend for doing this.
ie. what speakers, subs, sub box, amps, and converter so it will run off stock head unit.
thanks in advance
Old Jan 28, 2014 | 11:08 AM
pizzaman711's Avatar
What's your budget?
What do you want, SQ,SPL, somewhere in between, etc?
Old Jan 28, 2014 | 11:10 AM
FX4Matt's Avatar
Originally Posted by pizzaman711
What's your budget?
budget im not too sure of, kinda have to wait until tax time. im guessing around 800-1100.
im not really sure what you mean by the other things, sorry
Old Jan 28, 2014 | 11:13 AM
MGDfan's Avatar
SQ = sound quality = $$$$$
SPL = sound pressure level = $
One is NOT the same as the other. E.g - LOUD and CRAPPY can be done on the cheap. Just buy everything from Walmart
BTW - here's a sample build that you can use as a starting point. Ol' Peetz will have some reservations with some of the amp choices though
https://www.f150online.com/forums/sp...-upgrades.html
MGD
Old Jan 28, 2014 | 11:15 AM
SQ = sound quality
SPL = sound pressure levels
Somewhere in the middle = a mix of the two.
Basically what sound are you going for? All around quality that blends and creates a nice soundstage, a little bit clearer miss and highs with the big booming back seat, or just an upgrade over stock that fills in what's missing
Old Jan 28, 2014 | 11:21 AM
FX4Matt's Avatar
SQ = sound quality
im pretty much looking for a mixture of the 3 with a little more on the bass side of things
Old Jan 28, 2014 | 11:42 AM
MGDfan's Avatar
Yeah right ...
BTW - what "three" - he gave you Two choices.
MGD
Old Jan 28, 2014 | 11:44 AM
FX4Matt's Avatar
Originally Posted by MGDfan
Yeah right ...
MGD
HAHA not quite but sounds like some of my friends
Old Jan 28, 2014 | 11:46 AM
So you want it to sound clear while still being able to turn it up and shake the windows, onto the next questions..
Are you installing or paying for install?
Are you going to build the sub box, have it built, or buy a cheap prefab?
I'm assuming you want the sub to fit under the rear seat, correct?
Old Jan 28, 2014 | 11:54 AM
FX4Matt's Avatar
would be paying for install. most likely going with a cheap prefab and yes correct I want to keep it under the rear seat
Old Jan 31, 2014 | 09:15 AM
FX4Matt's Avatar
now im thinking about going to an aftermarket deck. double din nav unit. what all is normally needed? like is the rear view camera feed able to be moved from the mirror to the deck? am I able to keep the factory Sirius unit? would the steering wheel controls be able to be set to be used exactly like factory with an interface unit? would going this way be cheaper/give me better sound options as opposed to keeping stock head unit
Old Jan 31, 2014 | 10:28 PM
King Nothing's Avatar
hey all,
thanks in advance
What cab? Heres a little something for a supercrew
Sub box
http://www.foxacoustics.com/ProductD...50-SC-210-V-09
Subs (2)
http://www.woofersetc.com/p-11860-e-...subwoofer.aspx
Door speakers
amp
http://www.woofersetc.com/p-11499-oa...amplifier.aspx
Old Jan 31, 2014 | 11:16 PM
TK5's Avatar
TK5
That sub/box/amp combo would not be a good match. Two of those subs require 3-4 cubic feet of volume for a vented enclosure, the box you recommended is only 2 cubic feet. Two of those subs have an rms rating of 500 watts each, so you would want somewhere around 1,000 watts rms, but the amp you recommended is only rated at 500 watts rms.
I would not recommend putting 10" subs in any door.
Old Feb 1, 2014 | 12:24 AM
I don't know about moving the video feed, but I don't see why not. And I have no idea about the Sirius. But, there are harnesses available to make everything on the steering wheel work exactly like it should.
If you get the head unit from Crutchfield, you can easily do it yourself. It really is easy peasy with all of the super specific directions and wiring harness. Speakers are very easy as well. Subs and an amp are more complicated, but not bad. Paying for install on all of these things would eat up at least half of your budget. If you really don't want to install them yourself, find a buddy to help.
Old Feb 1, 2014 | 10:04 AM
TK5's Avatar
TK5
Looks like a perfect match for that box and amplifier combo would be the JL Audio 10WXv2 and wont break the bank either.
http://www.crutchfield.com/p_13610WX...1#overview-tab
