Door speaker terminals got wet?!?!
Lost my front left door speaker and took doorpanel off to inspect and found the terminals wet?? Sooo, is this another thing ford will tell me is "normal"?
Ill get another set of kappas, but how can i keep this from happening again?
Id also like to add.......i just did this install with infinity kappas in the doors and h avent amped them yet.......reason being, you cant just run wires thru the rubber boot on a 2010, its a plug in harness......do i just need to bite the bullet and drill holes with grommets and make some sort of boot between the door and the body of the truck?
Not sure about the water in the door. I have been told that it is normal to have a little water in the door sometimes but it should not be leaking. Maybe someone could hose the outside down while you sit in the truck, with the panel off and inspect for leaks.
You could also get some speaker baffles and cut them to cover the top half of the speaker. That should keep the water off of them.
http://www.crutchfield.com/S-YRPGc2o...e-3-depth.html
The kappas should not require too much power, so I think you could get away with tapping your amp wires into the existing factory speaker wire. That way you don't have to drill any holes. I could be wrong but have seen it done this way.
x2
I had a similar issue - my speaker was cutting out and I was convinced it was loose wiring from my DIY install but after a little inspection I noticed water in my plugs from my speaker (the adapters that plug into the OEM stuff). I dried them out and adjusted them so they would not "catch" any water if it got wet again and so far so good.
Good Luck!
FB
Good Luck!
FB
