Anyone have the Subnet box in Xcab 01?
I know Andy just recently changed the dimension statement on the two speaker box for the Xcab, but quite frankly I don't believe he is getting 0.72CF per side in that box. The pictures show that the box does not protrude past the seat, nor is the seat lifted, I measured everyway possible and it just does not seem doable. Has any one purchased this box and checked the internal dimensions.
thats actually my truck in his pictures. the speakers are 2 10" kenwoods that need .70 cf each. they sound just like they did in my other box(triangle shape from good guys) in my old pathfinder. i havent measured the "actual" inside volume but it works great. your right the seat isnt lifted and it doesnt extend past the seat. i'll try and get actual inside dimensions for you. mitch
thanks, i would appreciate it. The speaker I am considering needs 0.7 to sound right. I think his boxes may be more like 0.52. I just do not see how is getting this much volume and still using 3/4MFD board. The whole seat width is only 11 or max 11-1/2 inchs if it is to fit under the seat and not stick out, but still let the seat flip up and not hit the box, 50 to 50-1/2 max on lenght, and 5" to 5-1/2 max on depth, but only 5" depth max over the center hump. So using 3/4" MFD subtracts 1-1/2 " in each dimension, so you are left with 10 x 49 x 4.75 (internal depth dimension) or 1.35 cf, or 0.67/side. Now I know this is close to whathe says, but it seems hard to imagine him even achieving this. That doesn include the knoch around the seat support. I just don't believe it is right. Maybe 0.6 but not .75.
