Subwoofer
Old Mar 26, 2012 | 07:47 PM
cheeser's Avatar
Subwoofer
Helllo can anyone tell me if you can use a factory powered sub on a 2005 ford f150 crew fx4 in a 2012 f150 supercab xtr. Thanks
Old Aug 23, 2012 | 07:27 PM
ssandoval83's Avatar
probably not because there isnt an existing amp in the 2012 that can power it if it just has wires for sound going into the box but if you have both power and sound going into the box you are going to have to find out wich fuse is for remote turn on. (usually is going to say in the manual "accessory relay" or something like that) and run power and a line out converter to the box but even then you might have problems fitting it in the spot since its so cramped in the back but hope that helps
Old Aug 23, 2012 | 07:28 PM
oh and btw it would be better just to get an aftermarket system due to the audio quality
