sub popping! help plz!!
Old Mar 10, 2012 | 03:00 PM
LARABOY's Avatar
i have 2 digital design 1508's hooked up to a jl audio 500/1 wired like this (pic below) is this wrong?
Old Mar 10, 2012 | 04:08 PM
joh408's Avatar
Depending on the impedance of your subs you are either wired to 8 Ohm or 4 Ohm. 500W is not enough for even 1 1508, let alone 2
Old Mar 10, 2012 | 08:39 PM
Toyz's Avatar
I'm guessing you have the 12w1v2-4.
And your amp being 400.1
I don't know what they are wired to that way.. never seen that.
If they are dvc 4ohm subs they can be wired to 4ohms or 1ohm.
Parallel/parallel or series/paralles
Neither of which you have it wired at.
If your amp is not stable to 1 ohm then your options is this
http://a248.e.akamai.net/pix.crutchf...4-ohm_mono.jpg
Edit, your sig says you have 12w1 in custom enclosure so I assumed that is what you were referring to. You need to post what impedance your subs are for a proper wire diagram.
Old Mar 14, 2012 | 10:42 AM
LARABOY's Avatar
i updated my sig these arent going my truck.
thing is they were given to me so i dont really know the specs at all other then the stuff on the dd audio web site.
so i'm going to need something alot bigger then?
Old Mar 14, 2012 | 11:49 AM
pizzaman711's Avatar
The 1508's will want somewhere around 600rms of a piece but will take about 800 all day long of clean power.
Old Mar 14, 2012 | 11:08 PM
K.R.newbie's Avatar
rearrange the wires on the back side of the picture,, so they match + to + and - to -
