LAST SUB BOX for an Alpine SWR-T12
Old Mar 6, 2012 | 01:07 PM
easy smeasy's Avatar
well I picked up one of FX44AU's swr-t12s and started on the box yesterday. i figured i'd post a few pic as I go, along with posting the dimensions and such to help save others some time trying to figure out box dimensions. I swear this is the last box im building for this truck, 4th times the charm! I believe I've gotten alot better at it since the first build. anyway, the box is for 1 swr-t12 as i stated and will have a mouting dept of 4" max at the shallow part and just under .75 cu ft after sub displacement. the box is made of all 1/2" mdf other than the 3/4" mdf sides with a floor clearance of 1.5" and an overall length of 28".
dimensions are what i have figured at this point in the build
and here's some pics of the progress
im almost out of wood glue and have heard of others sealing theirs with liquid nail. is that a good substatution? i have liquid nail by the cases so if its not a problem, i'll just finish up with it. but if it's not as strong or something, i'll go pick up some more glue.
criticism, tips, and comments welcome
Old Mar 6, 2012 | 02:55 PM
Fke Snk's Avatar
Liquid nails is fine.
Post results. I have a dual 10" box from supercrew for my 07 stuffed w 1043 alpines and 1000watts and im not impressed at all
Old Mar 6, 2012 | 03:21 PM
Timelessr1's Avatar
Looks ilke you thought this out pretty well. My only critizism, would be that you used 1/2 in MDF for the longer sides of the box, and used the thicker MDF for the short sides. Most 12's recoomend 3/4 all around...but if you couldnt i would have used the 1/2inch on the sides and 3/4 on the rest. I'd use wood glue for the entire box...its the wood glue that actually gives the joints its strength, and then use silicone bead around every joint inide the box. Wait at least 24 hours BEFORE putting your sub in b/c the fumes from the silicone has been know to deteriorate speaker surronds
Old Mar 6, 2012 | 04:14 PM
I've never heard that before, thanks for the heads up! i usually wait for the glue to dry anyway, but still nice to know. as far as 1/2" wood, i needed to use it to get the correct mounting depth with the correct amount of ground clearance as well. braces will help the 1/2 mdf....and i figured glue would prolly be stronger, but liquid nail seems to work for others. i will most likely stick with wood glue, but still wanted to see others opinions
Old Mar 6, 2012 | 05:05 PM
Timelessr1's Avatar
I'm sure you wont notice a diffrence...but what you couldhave done for the bottom piece that old the sub was use 3/4inch and then router out 1/4 inch for the basket rim of the sub so that it would mount 1/4 higher....but by using the 3/4 inch wood you added much more rigidity which is what yuo want with a box....the stiffer and "more dead" a box is the better base response you will get...hence why ppl use MDF....medium "density" fiberboard. We used to use HDF some times too... wood glue is king with these boxes...ample amounts of glue, taked with small nails from an air gun......and wait 24 hours.....the glue is as strong if not stronger then the wood itself.The nails are just used for the initial hold together, after the glue dries the nails are really add no support what so ever.
Old Mar 11, 2012 | 11:57 PM
here it is finished up, along with my amp mounted. after i put the box under the seat, the weight of the box made the carpet sink down a little and the sub was too close to the floor for comfort, so i added a 1/2" piece to the front of the legs. gives me the clearance i needed and still doesnt pick the seat up.
Old Mar 12, 2012 | 12:57 AM
ErikShockey's Avatar
Nice setup, looks good. How much louder is the 12 compared to the 8?
Old Mar 12, 2012 | 08:49 AM
thanks, the 12 is a lot louder. its one of the hardest hitting subs that i've owned. its by far the best shallow mound sub that i've ever heard, but i've never had a chance to hear the stereo integritys. it hits harder the the 8" solo baric L7 i use to have as well. sounds great!
Old Mar 12, 2012 | 03:52 PM
mSaLL150's Avatar
Sweet install. I own the SI and have demo'd the Alpine in a truck. The output of the alpine is right on par with the BM, very similar. BM has a bit better low-frequency extension, and I recommend you stuff your box with ~.6 pound of poly-fill to help the Alpine with extension. You will like the difference.
Old Mar 12, 2012 | 04:22 PM
thanks for the tip, where do i find the poly-fill?
Old Mar 12, 2012 | 05:11 PM
mSaLL150's Avatar
Any craft store like Michael's should carry it, super cheap maybe a couple bucks for a 1 pound bag. Use a ratio of 1 pound of fill per 1 cubic foot of airspace in your box.
Old Mar 12, 2012 | 09:49 PM
Walmart has it too, in the craft section.
Old Mar 12, 2012 | 11:40 PM
stompy's Avatar
What was the angle you ended up cutting to butt up against the 7.5" board?
Old Mar 13, 2012 | 11:16 AM
ahh thats more like it! wally world lmao
to be honest, im not real sure. i cant figure out what the hell i did with my angle finder after the first angle i cut, so i cut 2 smaller pieces until i got the right angle. dont even remember what i set the saw to. i've been looking for it so when ever i find it i'll stick in on there and let you know. sorry lol
Old Jun 6, 2012 | 10:59 AM
gsxr1300's Avatar
do you know the internal volume of this box?
Im looking to use this sub in a .73 sealed box and wondering how it will sound
