2010 fx2 supercrew
2010 fx2 supercrew
What do y'all recommend on putting,in my,truck really want some bass looking,to get 8's or 10' which ever would sound cleaner. Maybe probox if I can find and get a good deal on it.
Well i will recommend doing 2-10's in the Foxbox....i have had mine for about a week now and this thing rocks...I had Rockford p3sd's at first and they sounded good but now i have 2 RE SEX10d4's @ 1ohm on a RE 3000.1 amp and holy siht...The bass is amazing....The box was 175.00 + shipping but it was well worth it IMO...I did have to enlarge holes on the box 1/16'' and pop off the plastic magnet covers on the subs so they would fit (gained almost 1 inch after removing)...but then they dropped right in...You will want a remote bass boost **** also if you listen to different types of music...I have a few pictures in my gallery of box and subs...
yep...I did use stock unit (6-disc/no nav)when i first started upgrading...it worked ok with loc's but wanted the nav and rear cam so got the 4200...Love it...i have replaced everything that i installed at first except the Pioneer headunit...Look at listen to and research your equipment.. then get what you want the first time...coulda saved myself alot of $$ if i would have....I changed door speakers 3 times before i found the best sound for me...You wont be disapointed with the foxbox...with a good pair of subs and amp it will shake everything on and in your truck...
