12" Sub boxes
12" Sub boxes
Hi everybody. I just purchased my first Ford pickup, well Lincoln Mark LT, supercrew. I work at a car dealership and ran into a good find, an 06 with 32K miles. I've been wanting a truck for a couple of years and finally got it. I love it so far.
I've got 2 12" Cerwin Vega HED's I've had for years. Still bump like brand new. I don't want to build a box, but if I have to I will. I'm looking for a place to buy a good enclosure to put under the rear seat. I will just go with 1 sub if necessary, but I'd like both.
Please give me some input on where to go online or any advice in general. Also, I prefer not to do much customization to the seat as well. Thanks!
I have seen dual 12's done with a seat lift and a custom box. I was able to fit two regular 10's under the rear seat with some modification to the underside of the seats and a custom box. These subs have a mounting depth of 5 inches and need .5 cubic feet of air space per sub.
The pictures prior to carpeting shows a little more clearly the space between the box and the floor. The box is closer to the floor in the front and is angled up as it goes back leaving more room for output
Here is a website I found with a dual 12 inch with a seat lift. Don't know anything about the box though.
http://www.supercrewsound.com/04F150SCrewUTSdual12.html
It is pretty expensive. I know if you dig around, the lift kit can be found cheaper. I was looking at it cause I have a set of RF 12 inch Power T1s and this is the only thing I could find that I could fit them in.
