sub/amp help
sub/amp help
I know this has probably been asked already but I haven't found anything that specifically helps me.
Anyway, I want a single shallow 12" sub. I am pretty new to car audio so I don't really know what I'm talking about. I don't know if I should go with a 1/2/4 channel amp or sub or dual/single 2/4 ohms. All I want is something decent, nothing too crazy. I have already installed a head unit and new door speakers but those will only be powered by the head unit and not amped up. The amp will only be powering the single sub. Also any recommendations on an amp/sub combo would be great.
Sorry for the newb questions, but thanks for any help and opinions.
would this combo work?
amp:
http://www.sonicelectronix.com/item_...ME-R500-1.html
sub:
http://www.sonicelectronix.com/item_...09P3SD212.html
or would the dual 4 ohm be better?
http://www.sonicelectronix.com/item_...09P3SD412.html
amp:
sub:
amp:
sub:
amp:
sub:
sorry the change the options here but I found a good local deal on an amp. its a pioneer gm-7300m for $50
http://www.crutchfield.com/S-IxWAS7K...-GM-7300M.html
I dont know if this would work with that sub or not, or if it is quality. Would I be better off sticking with the RF for a little more $$?
This one would be ok for a single voice coil 2 ohm sub such as this one correct?
http://www.sonicelectronix.com/item_...-SW3001S2.html
Thats what I thought. I can get this sub and amp for around $90 total so I think ill just do this for now until I decide to upgrade in the future. Thanks for the replies!
I got the amp for $60 and the sub for $79. More than I initially thought but still a pretty good deal. Its all hooked up now just waiting for the box to get here. Ill let ya know how it sounds once its in the box.
geez looks like a smoking deal to me. should really kick when done. after reading the reviews it seems the amp is going to be discontinued, so explains the great price, but the sub doesnt have good reviews. id stay away from the sub. good price but you could end up just throwing it away after awhile. for $100.00 you could get a kicker or JL 10" that should be a better product.
What box are you using? I have the same amp and a similar sub from my other vehicle. I'm trying to reuse the sub, but the box it's in, won't fit in the F-150. Thanks
