bail a noob out
Old May 31, 2011 | 02:27 PM
fordordie1's Avatar
bail a noob out
i have a 2002 scab with a UB-2200 pioneer head unit. wantin new speakers so that metallica will sound realllllly nice on the highest volume. would u recomend replacing all 4 speakers and if so what are there sizes/brands that would be good. thanks yall
Old May 31, 2011 | 02:50 PM
Kraft1982's Avatar
I installed 4 infinity kappa's 6"x8" speakers in my 02 Screw. Have 75 watts rms on each speaker. Sounds clear and has great mids and highs. I have a single 10" sub for the lows under the rear seat.
Old May 31, 2011 | 02:58 PM
Langlowe's Avatar
What is your budget and are they going to be amped or running off head unit?
Old May 31, 2011 | 09:29 PM
joh408's Avatar
Use the money for the rear speakers on a small 2 or 4 channel amp, upgrade the fronts, leave the rears. Amp the fronts with a 2 channel, amp all with a 4 channel. Check out Massive CK6III for nice midbass but you would have to seal/dampen the door for the best results
Old May 31, 2011 | 11:25 PM
Langlowe's Avatar
Rear speakers are only for the passengers in the back. They will have not bearing on you enjoying Metallica to it's fullest.
For the fronts go with a quality 6.5 component set with mid/woofer,tweeter, and passive crossovers. They will sound better than a comparable 5x7.
Leave the stock rears and just run off your Pioneer head unit.
The Massive Ck6 midbass speakers are ther real deal and I can attest to that. Bewared that if purchasing the entire set people have said the tweeters are a little bright but they are really loud.
To get the most out any 6.5 you will really want to run an external amp. For the massive look for at least 100x2 at 4ohm. Some people have been running over 200watts to them without any issues.
Old Jun 2, 2011 | 01:11 PM
fordordie1's Avatar
[QUOTE=Langlowe;4602189]Rear speakers are only for the passengers in the back. They will have not bearing on you enjoying Metallica top it's fullest.
so front is 5x7. and just leave the rears. sounds good. thanks everyone
Old Jun 2, 2011 | 09:20 PM
joh408's Avatar
Ya speakers are 5x7 so get adapters for 6.5 and you should be set. Get an amp for your fronts for best results
Old Jun 4, 2011 | 10:54 PM
fordordie1's Avatar
put new ones in..alot clearer then the old ones. best buy sold some 80 RMF idk what brand. but they are niceeee. wondering if i should do the back seats
Old Jun 4, 2011 | 11:12 PM
Lstruck's Avatar
Front speakers only, and fade the deck all the way to the front... You can do adapters, but I suggest doing your own baffles out of mdf, sealed with fiberglass resin.
Just depends on how far you wanna go.
Old Jun 4, 2011 | 11:20 PM
fordordie1's Avatar
fade front. didnt thinka that. ill set er up tomaro
Old Jun 5, 2011 | 12:13 AM
fordordie1's Avatar
also im guessing i didnt wire em backwards ?
Old Feb 19, 2012 | 07:37 PM
fordordie1's Avatar
well...i blew one out....birthday soon...might get myself a new set...all around...somthing around 200 or under. any sugjestions?
Old Feb 19, 2012 | 07:53 PM
NickGlass's Avatar
i suggest the infinity kappas all around, i have them in my ext cab and it sounds amazing with or without the sub on!
Old Feb 19, 2012 | 08:30 PM
pizzaman711's Avatar
Get a set of massives. Don't go to best buy.
Old Feb 20, 2012 | 12:59 PM
fordordie1's Avatar
http://www.crutchfield.com/p_113KFC6...ker_Size%7c6X8 these are what where in the front...i believe...wanted to get 4 of them...but are they 6x8 front and rear? i forgot
