Change of plans. Help!
Old May 16, 2011 | 10:27 PM
joh408's Avatar
Changed my plans of cutting up my front seat for a center console. Going with 2 8s now ported hopefully with careful planning and box design.
I need opinions on 8s tho. Heres what I've been looking at:
SA8
Pros: High SPL, high power handling (500W RMS), only need .5 ft^3 ported
Cons: 5.5" mounting depth, Large port area necessary
Tang Band W8-740P
Pros: 4.75" mounting depth, Highly regarded for sound quality
Cons: Not as loud, less power handling (150W RMS)
Similar to above:
Tang Band W8-1363SB
Pros: 4.75" mounting depth, Neodymium motor, Lighter
Cons: again not as loud, even less power handling (120W RMS)
Both model well in a .5 ft^3 each with smaller port area required
SoundSplinter Orphan 8
Pros: Loud, Ability to play low, TC2 based, High power handling, Model well in small enclosures ported
Cons: Not sure on mounting depth, More expensive
Budget of around $150 per sub. Any help would be appreciated
Old May 21, 2011 | 08:39 PM
joh408's Avatar
mSall? Anyone?
Old May 23, 2011 | 01:49 AM
weazel's Avatar
Registered User
SA8's will be the loudest, but the Orphan will probably sound better all around. The orphan mounting depth is 5.65", from what i hear the orphans take good amount of power to.. I haven't followed your post, but do you plan to put these under the rear seat? I also don't think those Tang Bands will get loud at all..
Old May 27, 2011 | 02:42 PM
joh408's Avatar
Ya I am going to go under the seat now. I think I am going to go with 2 SA-8s with an Audiopipe AP15001D amp. Doing more research into the orphans, I found out they like passive radiators more than ports so that swayed my decision to go with 2 SA-8s. Hopefully I can get the mounting depth I need with 3/4" MDF. If not I'll try a minor seat lift. If that doesn't work, I think I'm gonna go with some fiberglass.
