sub problem
Old Jan 12, 2011 | 03:46 PM
Underdog96U's Avatar
sub problem
Okay so i just built a box for my two new re sl12 d4 subs.
Box is a little too big for where i want it..
I have an alpine 450m amp
well i know for 100% that the wiring is correct have check double checked and triple checked.
My problem. Gain all the way down. Or half way up same thing.
I turn my radio up more than galf volume the amp shuts off
i am thinking a safety shutdown. But why??
Are my subs too big for my amp?
Old Jan 12, 2011 | 06:05 PM
Fabrik8edDreamz's Avatar
its possible what gauge wiring for power/ground? what is the RMS wattage for your subs and amp? also what ohm level are you wired at?
Old Jan 12, 2011 | 08:10 PM
Langlowe's Avatar
The 450m is a mono amp that is only 2 ohm stable. I am pretty sure with two dual voice coil subs you have them wired to 1 ohm and the amp is going into protect mode.
With 2 dual voice subs you have to wire at either 4 or 1 ohm. In your case you have to be 4 ohm. I am not sure if that amp will be able to adequately power those 12s at 4 ohm.
I would say get two 2 ohm subs or replace the amp with one that is 1 ohm stable.
http://www.rockfordfosgate.com/rftec...2&woofer_imp=4
Old Jan 12, 2011 | 09:42 PM
The subs are dual 4ohm voice coils. Wired in parelle they are 2ohm.
I over sized the power and ground wire at a 4g. Running 14g speaker wire.
Talking to a friend he belives that it probably my line out converter and the amp is going into protection mode.
I messed the box up so i am subless right now. But before i fix the box i am going to check out all my wiring for the line out converter.
But must say these subs arnt as loud as my cheap one was but they are so much more crisp. Cant wait to hear them at more volume
Old Jan 12, 2011 | 09:45 PM
Ohh. And i now see what your saying about the 1ohm. i have each sub parreled seperatly and then running into the amp. So it would be a 1ohm loud being seen unless i unplug one of the subs. Okay thanks for pointing that out
Old Jan 12, 2011 | 11:19 PM
Okay. I will run just one sub until i get a proper amp. what is a good 1ohm stable amp?
Just wondering a search on google didnt help. Would a boss audio cx1100m work? Or is that not a 1 ohm stable amp??
Old Jan 13, 2011 | 04:50 AM
Langlowe's Avatar
Check your other thread for suggestions. And no the Boss is not 1 ohm stable, sorry.
Old Jan 13, 2011 | 05:21 PM
Okay i just have one question about my box. I cant cut straight its a curse. Lol.
Well i was wondering if yall think that when i am done putting together my box if iy would work if i wrapped in one layer maybe two of fiberglass to cover any small holes came through via my horrible cutting. So that way i have a air tight box?...
If yall can follow what i am saying
Old Jan 13, 2011 | 10:57 PM
Langlowe's Avatar
I am no woodworker but I see people using resin on the inside of boxes to make them air tight. I don't think they are using mat just the resin.
Old Jan 13, 2011 | 11:10 PM
Well since i still have to make a back piece ( my 3/4 inch mdf puts it just a little too think. And i am yhinking i can get the back thinner and strong enough if i just fiberglass it. And if i do that i will just wrap the hole thing
Old Jan 17, 2011 | 03:23 AM
Low_e_Red's Avatar
How is this the same???
