03 F150 Install Log
Old Aug 20, 2010 | 06:27 PM
d2freak82's Avatar
03 F150 Install Log
I haven't been the best about taking pictures of my install, that or I lost the pictures when my phone broke cause I was too lazy at the time to email them to myself.
Anyways, I don't suppose I spent a lot of time on this install or anything, it was fun and challenging in many ways, the truck is an XL so I put electric windows and locks in, you'll see some of that in the pictures.
Here's the equipment
Eclipse 7200MkII
Power Acoustik BAMF 55001/D
MB Quart Discuss 480 (4 channel) running at 2 ohm
2 12" Diamond D6 Dual 4ohm
2 sets Gonzo 6.5" components running on active crossover (fmods)
Decka Marine Battery (A Beast)
Kinetik Battery (the small one not sure of specs)
Upgraded alt to 225 amp HO
That's about it actually! =)
I ran 0ga for everything from battery to distribution blocks which are under the passenger side from seat, if I could do it over I would put everything behind the rear seat, I don't think I had torn out the back seat yet to know it would fit though.
I put in Kicks for one set of components, they're Q-forms.
As far as the other woofers go, I put them in the door, I had to cut it out with a die grinder to make 6.5" woofer fit
The 4 channel amp went under the driver seat, which turned out really well, here's a pic of the wiring first one is before going under the seat.
Old Aug 24, 2010 | 08:24 PM
d2freak82's Avatar
I had to use trim rings to make this work, which made it hit the floor so that's no good, jacked it up a bit, and now it looks funny plus I want a ported box.
And here's working on the new box which I failed at a few times as far as how it was made, trial and error got me there though, still haven't finished but just need to tie up a few things and she'll be ready.
Old Aug 24, 2010 | 09:45 PM
Ray21's Avatar
Nice subs. That box looks like its tuned really high. Specs?
Old Aug 24, 2010 | 10:44 PM
Sundevil2188's Avatar
Is that ground under the truck?
If it is it needs some kind of loom or tech flex on it. Same with the stuff under the hood.
Old Aug 25, 2010 | 12:36 AM
d2freak82's Avatar
the ports are 4x20.5 for each sub, so I did (2)4x10.25 for each sub, which tunes it at 35hz
Old Aug 25, 2010 | 12:37 AM
d2freak82's Avatar
Yes the ground is under the truck, and I have loom here, and yes I need to do it I just haven't yet. I can't drive right now so it's not really an issue.
9/25 I get my license back, trying to get this done in the meantime
