My box plan
Old Aug 17, 2010 | 09:09 AM
symon_say's Avatar
My box plan
Hi
I want to share my box plan, is not mine, i just take a plan that i found on the forum a did some modification, for easy build, and get what i need.
this is the post where i take it:
https://www.f150online.com/forums/sp...home-made.html
This is the one i made, it as about 1.00 cu.ft, is made of 5/8" wood, to make separate chambers for each sub you have to put the middle wood in about 24.4" left to right, that will give you almost 0.5 cu.ft for each chamber can accommodate a 3" depth sub and have about 1 1/2"-2" of clearance. If you need more depth just add a ring where you mount the sub.
Old Aug 17, 2010 | 05:27 PM
LincolnMarkLT20's Avatar
Would this work for 12's
Old Aug 17, 2010 | 06:29 PM
mSaLL150's Avatar
Very similar to the dimensions of my box for the BMs.
Old Aug 17, 2010 | 09:34 PM
symon_say's Avatar
You just have to add more depth to the box, maybe 14" instead of 12", and might work for 12".
