Need some advice
Old Jul 27, 2010 | 08:59 AM
mav015's Avatar
Need some advice
I used the search button and it didnt help to much so i figured i start a thread
OK so my sub went out last night as i was driving, when i got home i took a quick look. The fuse it good, the wires are all connected and seem to be in fine condition. There are no lights on the amp which to means that theres no power coming into it. All the connections and the fuse seem good im alittle stumped any ideas?
Thanks Yall
Old Jul 27, 2010 | 12:27 PM
PorkCereal's Avatar
I might replace the fuses anyway. If everything is connected but not coming on, check grounds, make sure they are tight. Make sure the remote line is still good. If not, try swapping the amp with a buddy and see if maybe the amp is burned up.
PorkCereal's Avatar
Use a dmm at the + and - of the amp and see if your getting a voltage. If you are, then its amp. Also check between the remote and ground.
Old Jul 27, 2010 | 12:58 PM
mav015's Avatar
thanks man ill try it later when i get home
