HELP! subwoofers keep cutting out.
Old Jun 20, 2010 | 08:05 PM
kade8888's Avatar
Exclamation HELP! subwoofers keep cutting out.
just got a box and hooked up 2 10" pioneer subwoofers with a max power of 450 to a 720w pioneer amp. amp worked fine with one 12" rockford fosgate. So I don't know what could be wrong with it now. Please help!
Old Jun 20, 2010 | 10:43 PM
PorkCereal's Avatar
http://www.the12volt.com/caraudio/wo...igurations.asp
Use this. You probably wired the subs wrong and causing the amp to overhead and go into protect mode. Make sure final load matching amp specs.
Old Jun 20, 2010 | 11:46 PM
kade8888's Avatar
well the amp doesn't turn off or anything and I've also tried them on two different amps. With 2 different sets of speaker wire. Could it just be the subs?
